2WD Pickup Wheel options. Lowered mini truck.
What fits and What performs
Postby carwhisperer » Tue Apr 04, 2017 2:15 pm
I searched before posting, but it seems that most folks on this forum are into off roading, not street trucks.
I have a 2WD 89 SpaceCab. I am doing an LS1 swap. I want to put the biggest tires I can in the back, and I want to lower the truck a little (1-2 inches), so the wheels will go up into the wells at times. I have the stock Isuzu 12 bolt disc rear. I have done some measuring and it looks like there is only 2.5-2.75 inches of clearance between the hub and fender lip (if I roll the lip, I might be able to gain 3/8inch), and about 7.5-7.75 inches of clearance the other way, from the hub to the leaf springs or frame.
If my math is right, I think the biggest tire I can use is 255mm. Maybe 265 if I go crazy, roll the lips and add a Panhard bar to keep the axle from moving side to side.
I think theoretically I could fit a 10inch wide rim, but I don't think I need that given the tire width restriction. So I am thinking 255/xx/17's or 255/xx/18's on 9 inch wide rims.
I want the wheels to come as close to the fender lip as possible. So I think for a 9inch rim I need a positive offset (inward) of about 1.25-1.5 inches, or about ET30-40.
Most modern 6 lug rims I have found have a knobby off road look. I really like the torq thrust look. I know it's not for everyone. I have seen some close to those specs. I am open to other looks. I am not a big fan of black. Polished aluminum would be my ideal.
Who has any experience with this on a pickup? I assume a Rodeo would be about the same situation, although even less likely to find someone with a lowered one.
carwhisperer
Re: 2WD Pickup Wheel options. Lowered mini truck.
Postby geoffinbc » Sat Apr 08, 2017 4:05 am
Yea it takes good measurement. There are low cost tools tou can buy to make it easy and check for clearance.
I would not wish a bare polished aluminum wheel on my worst enemy (ok yea I would) they are horrible. You polish the things as much as you drive them. I really like the low shine too so I would suggest finding a way to clear powder coat them if possible. Otherwise a coated or chrome wheel is the way to go.
geoffinbc
Has thanked: 8 times
Have thanks: 324 times
Postby itsmehb » Sat Apr 08, 2017 4:59 pm
geoffinbc wrote:Yea it takes good measurement. There are low cost tools tou can buy to make it easy and check for clearance.
I'll second the above on polished aluminum wheels. I have the snowflakes that are so popular on my 89. I had the wheels refinished, and there clearcoated. However to save a little I finished the spare myself, and it's polished. I find myself polishing it at least once every week to keep it looking nice. I couldn't imagine having to do that on all the wheels.
1991 Pick up (long gone)
2000 Amigo, 2.2 5 speed(sold)
itsmehb
Has thanked: 116 times
Have thanks: 209 times
Return to Wheels & Tires
