New 33" tires rubbing lifted Trooper
What fits and What performs
Postby ducktrooper1 » Mon Mar 27, 2017 8:32 pm
I recently switched from skinny tires to 285/75/16 BFG AT's. The added width of these is rubbing my wheel wells and fender flares, in spite of my 3-3.5" lift and TB crank. This was never an issue with my previous 255/85's. Anyway, I don't want to lift any more so what do I cut and how do I go about without making a mess of things? Any photos or posts will help. Thanks in advance
99 Trooper S, 4.77s, ARBs, ARB bullbar, M8000 w/Amsteel, OME 4" lift, IFS Lights, Rancho 9000xs, Aisins, BFG KO2s 285/75/16, custom sliders, K&N/Magnaflow custom, Indy 4x SS lines, Indy 4x disconnects, DOR diff drop, Hayden cooler.
ducktrooper1
Drives in Mud
Re: New 33" tires rubbing lifted Trooper
Postby paulevans76 » Tue Mar 28, 2017 10:22 am
Turn your tires all the way each way, and look at what is above each of the edges. That ought to get you started. Whether you cut or hammer or both, go a little at a time, test, and repeat until you're not getting any rubbing. Make sure you test some flexed out and turned each direction. You may decide to do a small body lift if the cutting is going to be extensive, or you may need a different wheel offset/width, or both.
Has thanked: 83 times
Have thanks: 86 times
Postby BigSwede » Tue Mar 28, 2017 11:35 am
I'm guessing you have aftermarket wheels?
BigSwede
Has thanked: 16 times
Have thanks: 252 times
Postby ducktrooper1 » Tue Mar 28, 2017 2:23 pm
No, I switched back to the OEM Trooper 5 spoke rim and tires still rub. They really have some meat on them. I have OME 912 coils in back with 2" poly spacer and approx. 2.5-3" of TB lift in the front. Am trying to avoid lifting any higher b/c I wanting to improve overall handling and road manners since most of driving will be to and from off road spots.
ducktrooper1
Drives in Mud
Postby BigSwede » Tue Mar 28, 2017 3:15 pm
Weird. I have 4" lift with 35x12.5 tires and wheels with less backspacing than stock, basically no rubbing except a little at absolute full compresson. I did have to massage the back of the wheel well and knock that standing seam down, but I wouldn't consider it drastic surgery.
BigSwede
Return to Wheels & Tires
