A little expert help please!
What fits and What performs
Postby Salebus » Fri Mar 24, 2017 8:48 pm
I'm sure this question had been answered in part on the forums several times between many different posts, but i'm new to the tire/wheel game so I thought I'd ask it again. I have a first generation 1991 Isuzu Trooper with no lift and I want that Tall Skinny look, but I am also on a budget.
Listed below is the Wheel and Tire combo that I "think" will work and I just want to make sure before I go purchasing it online. I know the Pilot Diameter is too small, but that can be milled larger. I am not sure about how the offset works or the "bead" of the tire vs the rim. Anything else I'm missing let me know.
RIMS:
http://shop.redneck-trailer.com/p-768-dexstar-16-x-6-oem-wheel-655-wh166-60e.aspx
TIRES:
http://www.powerkingtires.com/Tires/Highway/Bias%20Light%20Truck/1614
Salebus
Re: A little expert help please!
Postby nasty610 » Sat Mar 25, 2017 7:40 am
Those rims don't list the offset so I personally wouldn't waste the money to buy them. The tires will fit just fine. Why don't you just use the stock steel wheels that come on 1g Troopers? They aren't usually pretty easy to find and cheap. Or buy a set of Toyota Tacoma steelies which are a direct fit.
1996 Isuzu Trooper Base model
1991 Trooper Base Model
Lift Coil Spring Options
nasty610
Has thanked: 21 times
Have thanks: 208 times
Postby RickP » Sat Mar 25, 2017 7:53 am
The wheels list zero offset which would be a 3.5 backspace on a 6 inch wheel. The hub bore is too small. You need a 108mm or 4.25 hub bore. Also, those are trailer wheels, not sure if they would be ok on a vehicle.
According to the thread below, you can fit a 33" tire, but I'll let more experienced folks answer that. The tires you posted are bias-ply, I'm not sure I would want a bias ply tire on my vehicle. http://www.planetisuzoo.com/viewtopic.p ... +gen+tires
RickP
Has thanked: 34 times
Have thanks: 42 times
Postby itsmehb » Sun Mar 26, 2017 8:01 am
Looks like you want something similar to what Andy had on his blue one. He hasn't been very active lately and he did sell the blue one and is probably working on another project
1991 Pick up (long gone)
2000 Amigo, 2.2 5 speed(sold)
itsmehb
Has thanked: 115 times
Have thanks: 201 times
Postby mdc0135 » Sun Apr 02, 2017 9:58 am
if you have an 16 inch wheel set up you can do a 235/85/16. to do a tall skinny look
mdc0135
Return to Wheels & Tires
