2000 Rodeo LS 4WD Build Thread
Re: 2000 Rodeo LS 4WD Build Thread
Postby Rodeo814 » Fri Apr 14, 2017 2:42 am
So I decided to make myself a camping/utility table out of the tailgate door. I seen a lot being sold for jeeps and stuff. So I made my own. I must say this project took like 2 months to complete. I only had sundays to work on it and spent most of the time waiting for paint to dry. Lol
All in all I am happy with the way it came out. It took longer than expected but oh well.
Material: 1/2" Plywood, Nylon straps, aluminum angle, bed armor spray paint.
Before mod
Measured out the interior panel and cut two pieces of plywood to match and fit. Had to round off the edges to fit the mold
First I had decided to use cable wire to hold the table up but I did not like how stiff it was when the table was closed.
Next I cleaned up the tailgate door. To bolt the table to the door I used 4 existing holes that were already treaded.
After adding the aluminum angle I had to spray paint to retouch.
I decided to use nylon straps that I got from Ace Hardware because when I closed the table the fold perfectly inside the table. I first did a few coats of bed liner then finished with some shellac.
Table getting a little light use.
2000 Rodeo 4WD 3.2 V6 (133K)
4.10 Gears factory LSD
OME 912 springs, Rancho9000XL shocks, HD torsion bars, HD lower links, Calmini Upper Control arms
BGF KO2 285/75R16
Yakima Road Warrior Rack
Rodeo814
Postby Rodeo814 » Fri Apr 14, 2017 3:33 am
Got my 4.77 gears from egagnon086 a couple weeks ago. Once those 285/75/16 BFG KO2 went on I really felt a loss of power. My last trip to Big Bear left me barely getting up the hill. My rodeo felt super sluggish. I am excited to see where these gears will put me once installed.
Spent some time stripping and cleaning up the third member. Install will start once I decide on what locker will be added to the rear.
Out the box:
Applied some Loctite rust dissolver to get rid of the rust.
Primered and painted
BGF KO2 285/75R16
Rodeo814
Postby ZuminaZX » Fri Apr 14, 2017 1:01 pm
Awesome table. I I have wanted to do something similar for a while now but my tailgate is so high it wouldn't be very usable. You might consider adding a few more anchor points by drilling the sheet metal and install rivnuts. I was looking at this aluminum JK table with slide out cutting board/extra shelf
https://jeep.rebeloffroad.com/product-p ... lgater.htm
2004 Rodeo 3.5 DI
ZuminaZX
Have thanks: 24 times
Postby OlRob65 » Fri Apr 28, 2017 12:26 pm
spartancub wrote:ya I've done some reading and seen that some people have completely disconnected/deactivated their ABS systems.... I'd rather not do that if possible.... will know more after this weekend.... like I said, this truck is one hobby that provides ENDLESS opportunities to keep me busy and broke! LOL
How did the tone ring work? Were they hard to find? I've got the ABS light too, so I'm curious. I've read about some guys taking the ABS box apart and finding cracked solder on the circuit board. When they resolder it fixed the trouble light. I'm with you on not disconnecting it, when I bought my Rodeo they guy had the fuse out so the light would go off.
OlRob65
Has thanked: 4 times
Previous
