The amigo like no othere amigo
Postby dirtjunky520 » Thu Jan 05, 2017 1:36 pm
Got grand cherokee springs kn the rear ball joint flip. Front sway bars off. Amd t bars cranked. With a little cutting. 33-12.50r15 custom rear mount winch and rear bumper. Shes a work in progress but comming along
dirtjunky520
Re: 1999 amigo
Postby Toccoa » Fri Jan 06, 2017 10:19 pm
Looking mean. What size tires are you running?
2002 Rodeo Amigo Sport
V6 Auto RWD
Currant Red Mica Lagoon Blue Matte Metallic Thundercloud Metallic
1" Wheel Spacers
General Grabber AT2 255/70/16
1" Suspension Lift (coil spacers from Indy4X)
Build Thread Vinyl Wrap Samurai
Toccoa
Has thanked: 64 times
Have thanks: 48 times
Re: 1999 amigo
Postby dirtjunky520 » Tue Jan 10, 2017 1:28 pm
33x12.50r15 road warrior m/t200's I love the tire and good price to 640 shipped to my door
dirtjunky520
Re: The amigo like no othere amigo
Postby dirtjunky520 » Tue Feb 14, 2017 9:22 am
Did some good wheelin at rocks and vallys in mi this past weekend the new front shock mounts held up good. But broke my rear shocks. Witch means time for some new ones!!!! And got a P.S leak some where so back in the garage she goes will have some pics of my shock mounts soon
dirtjunky520
Postby egagnon086 » Tue Feb 14, 2017 2:01 pm
Looking like a good trail truck build, You need to find a Rally aftermarket top so you will get your rear window back. It will help keep the cold out.
I'm going to start using your truck as an example of how much fender needs to be trimmed to fit 33's so they don't rub. I like it.
egagnon086
Has thanked: 44 times
Have thanks: 78 times
Postby dirtjunky520 » Tue Feb 14, 2017 10:47 pm
Thank you and it still rubs when im really flexing it out in the trails so I think im going to do a small body lift like 3 inch. If I crank the keys any more I will need to get the drop control arms and make diff drop brackets witch I plan on doing just not roght now. Have to take a brake from the welder lol
dirtjunky520
Postby egagnon086 » Wed Feb 15, 2017 9:48 am
I hear you, Not sure what you mean by "Drop control arms" unless your talking about the Calmini ones, which aren't really required for lift. The diff drop would be required at those extreme cv angles will break them.
Don't get yourself a welder tan, I know id be seeing spots I was welding as much as that.
egagnon086
