Jim's new ride 97 Isuzu Rodeo
Re: My 88 Trooper Christine
Postby shaggydoink » Sat Apr 30, 2016 8:38 am
PPCLI-JIM wrote:Well i started in on the ITECH minimizing and came across this oddity :shock: :?: ... the pull cable has a bolt and nut to act as a keeper but I have no idea as to what the heck its for.
Perhaps it's a cable for a cruise control that was removed...? Where does the other end go?
Shaggy
Has thanked: 726 times
Have thanks: 377 times
Postby PPCLI-JIM » Sat Apr 30, 2016 5:52 pm
Postby kg4miq » Tue Apr 26, 2016 2:12 pm
That's the pressure adjusting cable for the automatic transmission on a four-cylinder Trooper. It is normally connected to the throttle linkage, but most of the time, the cable sleeve separates from the ferrule on the end, causing it to become useless if left connected to it's normal spot. It is not uncommon to find these cables zip-tied to the firewall somewhere. It adjusts the shifting pressure (think: firmness of the shift) of the Aisin AW30-80LE transmission. Looks like someone has set it to whatever setting they felt was best for shifting.
So because im a slow old fart it takes me a while to do this type of work.. I have tucked into the rest of removing and modifying the ITEC to the 5TEC system .
as I live up here in the Land of the free Canada EH?. I dont need to worry about tech inspections like you southern guys. Heres a few pics as i Dither and Dally my removal mod and replacement. As ive been having some issues that point to a possible EGR valve issue i decided i have the gasket make an inspection as i am here anyway .
97 Rodeo AKA the Pavement Princess.Maybe ill just keep it fairly stock but more capable ... And the 88 Trooper II Christine viewtopic.php?f=15&t=86504
The wild Infantryman is never truly happy in a domesticated role, though they may act like it with their stories of deployments past and the suffering they have endured.
PPCLI-JIM
Trail Rider
Has thanked: 30 times
Have thanks: 10 times
Re: Jim's new ride 97 Isuzu Rodeo
Postby PPCLI-JIM » Sat May 21, 2016 1:17 am
umm thats not right.. guess what i be doing tomorrow
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Sat May 21, 2016 8:25 pm
as the bottom was already off this was quick and easy once i got all my stuff together. took a grinder w cutoff wheel and zipped the top shaft the shock dropped out into my hand. from there it was pull the now free shaft with bushings washers and nut out. in went the new one the longest part of the swap was the fact that i had to use a combo wrench to tighten the nut on the shaft down . bottom one was easy with the impact wrench. the other side promises to be more of a pain due to the location of the top shaft .. Right next to the fuel cell.. this one failed at the weld
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Mon Jul 25, 2016 8:22 pm
well curse my luck . things have been going great with the rodeo until yesterday it decided to spit a brake shoe somehow and now the rotors eaten the caliper piston does anyone have a spare driver side rear caliper? . i managed to jam it back in as it did not ---- just wore . replaced the pads and now am looking for a caliper ... GRRR oh well if it wasnt for bad luck id have none at all .. false i manage to get up and move each day its a good day
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Sun Jul 31, 2016 5:13 pm
Well it's been a bit since I've tinkered with this buut I'm working on it again. I was out at the range the last week and a fellow shooter told me hes got a friend who has a few and may want to sell one or two. Well I contacted him and for 500 $ i can go out to Alberta and strip one down to drag back parts on my weeny trailer. Sweet he sent me a few photos and while they are not in great shape i can definitely make hay out there. :D a set of manual hubs/ steering, hubs a arms motor from a 2.3 with carb setup complete, 5 speed trans with drive shafts and mounts rear axle , (im hoping a lsd) rims doors maybe seats ....For 500$ its a great deal maybe sneak a few parts from another one anyone need anything specific ? :wink:
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Sat Aug 06, 2016 10:52 pm
Well IT lives !!!!!!!!!! i will take a few snaps and video tomorrow.. along with all the usual hoses and wires to connect.
well one hose is holding m up as i need the one the goes from the firewall to the back of the motor and connects to the water out on the intake side. SOOO close :evil:
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Fri Aug 12, 2016 1:33 am
:shock: well curses . for some reason or other it dont want to stay running i think i have to get my egr hose connected and charge my battery fully before i get too upset. I really want to pull off my John 5 style parts run out to AB.Id love to be able to swap out to a carb system. i was talking with him and he says you can go carb with a auto even with the standard Throttle positioning sensor. just have to glue it into a position it shifts reasonably at .. easy enough i guess. well if it dont work Ill through the standard trans in and go from there :shock:
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Fri Aug 12, 2016 7:43 pm
https://youtu.be/HH4R5jMl8zk sorry for the sideways action any idea whats causing this ? it sounds like its not getting fuel i have all the vacuum caps on but not the Exhaust tube to the itec, or the main filter to the itec
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Sat Aug 13, 2016 10:20 am
So i sent a email and link off to Johnny 5 and he replied in under 1/2 hour "PUT THE MAIN AIR TUBE FROM THE FILTER TO THE MANIFOLD'. did that now it runs fine , I am however having pain at trying to fit my exhaust tube into my manifold seems i bent it a fraction and now its another fight. Man cant anything go easy for me on this thing...
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Tue Aug 23, 2016 6:33 pm
https://www.youtube.com/watch?v=enPQth9XCfI
Well here she is ,does this under load and when warm. fresh head gasket valves adjusted vacuum system minimized egr gutted . any ideas :oops: :?:
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Tue Aug 30, 2016 1:36 pm
Well i went shopping at the local Lordco for new cap ,rotor, wires and plugs .. well i got rotor and cap ... turns out they are not f deppression , but a friend ordered me a new set from a different place with a different manufacturer . be in tomorrow and hopefully this will be the end of it (Mechanical issues) :| .I hope ... 8)
PPCLI-JIM
Trail Rider
Postby RickP » Tue Aug 30, 2016 9:58 pm
Good luck.
RickP
Trail Scout
Has thanked: 24 times
Have thanks: 31 times
Postby PPCLI-JIM » Wed Aug 31, 2016 2:15 pm
Roof rack done ...check
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Mon Sep 05, 2016 12:08 am
So I finally got some spare time and put the plugs wires cap and the correct rotor and IT WORKS !!!!!!!!! crap well i know the upper end will last me a while now as ive been through it all ! i have to go to the coast this week but when i get home ill take it out and about a bit and give it a sign off as its HUNTING SEASON ! :D This is what i have waited for . man im so happy that its done by this season 8) :lol:
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Sun Sep 11, 2016 9:07 pm
I took her out today to do some hunting I got a grouse out of the half billion i saw ... Well ok it was a covey of 7 or so Got one had a great day
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Tue Sep 13, 2016 11:31 pm
Made a stove table for the back of my Trooper II. & Got a free stove from my neighbors just had to replace a screw. — feeling accomplished. 8) Sorry they are in reverse order . Just have to add a cable to hold it and a way to keep it upright and not rattley :P
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Wed Sep 14, 2016 4:02 pm
Finished off my latest stealth project for Christine. I am done except for the final wipe down.
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Sun Sep 18, 2016 12:18 am
Arts and craft time fellow enthusiasts of the Zoos.I got bored tonight and laid out my next mod of my Trooper II Christine. Ive got 3 cross body roofracks :D Now its hunting time its put more emphases to get it made and done but he big stalling point is $ . So without further delay, heres my next addition to my ZOO. a RTT or hunting blind depending on how I rig it. :wink: Base will be 1 piece of 5/5" plywood side a piece of 1/4 " plywood front and rear also made from 1/4" then a heavy tarp to act as the roof / weather break . Easily installed and removed put up and taken down .
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Sun Sep 18, 2016 6:24 pm
I'm finally just knocking the rust off with a friend, hes not used to hunting with his new glasses he claims. Me i cant hit the broad side if a barn but il lower the roof on them . Thats 2 so far for me Chris none lol but we had a good day except for the fact i blew my egr pipe thats plugged at the far end off . So I have to close up the other end and be done with it. as I disconnected all that crap when doing the intake system. undo the nut / connector when it cools then weld a piece of 1/8 plate over it put it back together Ill have that done tonight 8)
PPCLI-JIM
Trail Rider
Postby Torquemonster » Tue Sep 27, 2016 1:29 am
Hi from Lower BC! I like the work youve done, and Im gonna copy your front winch mount, possibly your rear hitch Idea for my 87.
If you go with the carb, I reccomend you ditch the stock hitachi carb, and go to a Weber. They come up used every now and then, and the adapter plate from a Nissan will work in the carb'd manifold. I also think you need the distributor from the 2.3 motor.
1987 Trooper 2 door MSG-5 4ZD1 Weber 32/36 31"s viewtopic.php?f=15&t=87854
95 Rodeo 3.2 V6 MUA-5 4.10 gears 33" Yokohamas 3" lift SOLD http://www.planetisuzoo.com/viewtopic.p ... 5&start=25
1990 Trooper LS 2.8 5 speed 2" lift 31's (my dads rig)
Previously: 88 Trooper 2.6 MUA-5 3.5" lift 33"s 4.77s Aisin hubs, 89 Trooper 2.6 automatic no lift 31"s, both my dads
Torquemonster
Super Trooper
Has thanked: 7 times
Have thanks: 13 times
Postby PPCLI-JIM » Fri Oct 14, 2016 12:21 am
Yes i will take a few months to build up some funds so i dont have to nickel and dime the set up. IN the mean time i have a friend up here from the coast , weve been smashing around all over the place from here in Merritt to Savona
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Sun Oct 16, 2016 11:33 am
so after 4 days of torture testing something finally gave .. about 1.5 hours away from home and about /2 hour up a dirt road i became aware of a squealling noise from the back end. . well i cant do anything about it there once i saw the issue . well after getting it home I saw this the next am .. off to the lordco for parts be in tomorrow they say.... jeez just my luck 3rd rotor to go on this beast . two fronts now one rear.
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Sun Oct 16, 2016 8:05 pm
WELL NOW !!!! i just recalled my tire chains will need to be resized as they fit too deep on these narrower smaller tires 2.35x75x15r vs 31x10x15. I made my tire chains from a set of triples off a 18 wheeler logging truck/ the side rails are too long for my taste and come a little too close to the hub / axle assy . considering i have sets for front and rear i want to have then sized right or i can tear up some expensive stuff. pics to follow when i get the tire pliers and parts for repair of brake system until then I am using the PAVEMENT PRINCESS (T.M.) :?
PPCLI-JIM
Trail Rider
Postby PPCLI-JIM » Thu Oct 27, 2016 9:35 am
well now after taking it out hunting last weekend it sounded like it was running a little rich so i pulled the plugs and now its DEAD again. spins but no spark... I suspect the ignitor box as its the likely suspect. found one used 100 $ ouch but if thats the cost of keeping her alive so be it :oops:
PPCLI-JIM
Trail Rider
Users browsing this forum: Bing [Bot] and 1 guest
