Just comeback; 4JA1 ,2WD
Re: Just comeback; 4JA1 ,2WD
Postby gear60 » Tue Mar 08, 2016 11:50 pm
totten wrote:Another trip with your friends,great! How's the turbo doing? Would like more pictures of turbo setup and BTV 9" lifts on your friends rides. Thanks for pics. Tony :D
hi,
my Turbo is too much power and over for using , I just setup only 15psi of boost for safety my engine 2500cc Di .555
:D
gear60
Trail Rider
Has thanked: 16 times
Have thanks: 9 times
Postby totten » Thu Mar 10, 2016 11:34 pm
Sweet Ride!! Thanks. :)
totten
Have thanks: 83 times
Postby totten » Sun May 08, 2016 8:46 pm
Where have you been? Any more pics. or mods done. :evil:
totten
Postby gear60 » Tue May 31, 2016 5:06 am
totten wrote:Where have you been? Any more pics. or mods done. :evil:
Hi,
I replaced Horn , and new wheel,new tire
gear60
Trail Rider
Postby gear60 » Tue May 31, 2016 5:11 am
more , new wheel, new tire
gear60
Trail Rider
Postby gear60 » Tue May 31, 2016 5:24 am
Amy more modifications, Upper control Arm too lift more 2"
gear60
Trail Rider
Postby totten » Wed Jun 01, 2016 10:56 pm
gear60 wrote:
WOW, different Upper control arms and shock in middle of arm.
gear60 wrote:more , new wheel, new tire
Thanks for pics,Tony
totten
Postby totten » Sun Jul 03, 2016 7:52 pm
Like the way you insulated the under hood parts from exhaust turbo heat. I had a idea for you ,may be vent the hood on top of turbo area or add a scoop for air. Would help with heat and save the under hood engine components from heat. Nice pics,thanks,Tony :idea:
totten
Postby gear60 » Wed Jul 06, 2016 5:50 am
totten wrote:Like the way you insulated the under hood parts from exhaust turbo heat. I had a idea for you ,may be vent the hood on top of turbo area or add a scoop for air. Would help with heat and save the under hood engine components from heat. Nice pics,thanks,Tony :idea:
Hi, Tony
thank you for your recommended,
gear60
Trail Rider
Postby gear60 » Wed Jul 06, 2016 5:57 am
Driving now
gear60
Trail Rider
Postby totten » Thu Jul 07, 2016 11:05 pm
Thanks for picture of Rodeo-looken great and green color. You have a lot of height in rear ,did you put axle under springs? SOA-SPRING OVER AXLE. Was going to add spring spacers to mine ,but my wife has hard time getting in with 5"lift I have now,so i'm not going to add them. Here is pic of mine.
See you later.
totten
Postby gear60 » Wed Jul 13, 2016 2:35 am
Hi, Tony
Here is my rear, and have not any Spring and spacer, only leaf spring of isuzu Mu and shock up sit on axle.
and also, I just wear new shoe, 55555
bye
Porn
gear60
Trail Rider
Postby totten » Wed Jul 13, 2016 10:09 pm
Lookin good GEAR60. I see drum brakes on rear and fuel tank on right side.Added brake line extention on axle. Nominated your Cameo for JULY 2016 ride of the month. Good luck,TONY :!:
For this post the author totten was thanked by:
gear60
totten
Postby gear60 » Thu Jul 14, 2016 5:32 am
totten wrote:Lookin good GEAR60. I see drum brakes on rear and fuel tank on right side.Added brake line extention on axle. Nominated your Cameo for JULY 2016 ride of the month. Good luck,TONY :!:
Hi,
Thank you
gear60
Trail Rider
Postby gear60 » Sun Jan 29, 2017 3:52 am
Hi,
I am here.!!
:D
gear60
Trail Rider
Postby totten » Sun Jan 29, 2017 2:24 pm
Thanks for Group Picture. Hope you're doing well and all is good here in Ky.
gear60
totten
Postby gear60 » Mon Mar 20, 2017 2:35 am
Small group for trip.
gear60
Trail Rider
Postby totten » Sun Mar 26, 2017 11:38 am
Thanks for pics. of your group. VERY NICE 8)
totten
Previous
Users browsing this forum: Bing [Bot] and 2 guests
