1999 AZ Trooper project
New wheel decals
Postby jc_in_az » Fri Nov 25, 2016 5:22 pm
The center decal on my old ASA rims were losing the battle with the sun. So I hit up Ebay from some Isuzu resin decals that happen to fit perfectly.
jc_in_az
Drives in Mud
Have thanks: 6 times
AZ TROOPER
Postby jc_in_az » Fri Nov 25, 2016 5:24 pm
Just a pic of her sitting on her skinny tires (255/86/16).
jc_in_az
Drives in Mud
NEW (to me) Wheels
Postby jc_in_az » Tue Jan 10, 2017 1:47 am
Picked up some rims from a 2000 Trooper, and painted them up with metallic gray Peel Coat
jc_in_az
Drives in Mud
Posing for the camera
Postby jc_in_az » Tue Jan 10, 2017 1:51 am
jc_in_az
Drives in Mud
Re: 1999 AZ Trooper project
Postby bradzuzu » Tue Jan 10, 2017 1:58 am
Very nice look now !!
For this post the author bradzuzu was thanked by:
jc_in_az
Has thanked: 198 times
Have thanks: 362 times
Offroading Videos
Postby jc_in_az » Tue Jan 10, 2017 1:59 am
File format: mp4
File format: mp4
File format: mp4
File format: mp4
(The same place I broke a CV axle before having the front and rear axles welded up)
File format: mp4
jc_in_az
Drives in Mud
Changing front lights
Postby jc_in_az » Tue Jan 10, 2017 2:05 am
Decided to change up the front lights to something a little brighter than the curved LED bar.
(BEFORE AND AFTER)
jc_in_az
Drives in Mud
Postby jc_in_az » Tue Jan 10, 2017 2:11 am
bradzuzu wrote:Very nice look now !!
Thanks, brutha! It seems like there's always something to change or upgrade.
jc_in_az
Drives in Mud
Postby leftarmtan » Tue Jan 10, 2017 4:08 pm
I know the big one's are Auxbeams,what are the smaller amber lights? Looking to add some amber to mine for the dusty situations.
89' trooper SAS 4.3
April 2014 ROTM
leftarmtan
Has thanked: 15 times
Have thanks: 12 times
Postby jc_in_az » Tue Jan 10, 2017 5:31 pm
leftarmtan wrote:I know the big one's are Auxbeams,what are the smaller amber lights? Looking to add some amber to mine for the dusty situations.
Run-D amber cubes (Amazon). $107 for the pair. No wiring harness.
jc_in_az
Drives in Mud
Postby leftarmtan » Tue Jan 10, 2017 5:37 pm
Awesome, Thanks
89' trooper SAS 4.3
April 2014 ROTM
leftarmtan
Postby jc_in_az » Tue Jan 10, 2017 6:26 pm
leftarmtan wrote:Awesome, Thanks
No problem. These lights are FAR brighter than those amber bulbs I put in the fog lights.
jc_in_az
Drives in Mud
Postby e30dean » Wed Jan 11, 2017 5:12 pm
Man I love you build so much!!! Especially the color on there. Mine is currently red and could use a respray on the roof and one quarter panel. Did you end up spraying all the door jambs, engine and trunk compartments also?
For this post the author e30dean was thanked by:
jc_in_az
e30dean
Postby jc_in_az » Thu Jan 12, 2017 12:46 am
e30dean wrote:Man I love you build so much!!! Especially the color on there. Mine is currently red and could use a respray on the roof and one quarter panel. Did you end up spraying all the door jambs, engine and trunk compartments also?
No. Just the outside. The jambs are the factory green as you can see in the first page of my build. I would've had to let the guy keep it an additional week, which would've jacked the price up more. It's only a trail rig, after all.
jc_in_az
Drives in Mud
Postby Carl747 » Wed Jan 25, 2017 3:37 pm
On the first Page of this build you mentioned that you would move the light bar in the grill if it caused heat problems. Did it end up having any effect on the engines temperature, or did you just like it better somewhere else. I was looking at doing a similar change to my Trooper and yours looked quite nice. I was also looking at placing a light bar where you have your wench, I do like the idea of a wench there much better.
98 Trooper S. 230k miles, Dark Blue.
Carl747
Has thanked: 4 times
Postby jc_in_az » Wed Jan 25, 2017 3:46 pm
Carl747 wrote:On the first Page of this build you mentioned that you would move the light bar in the grill if it caused heat problems. Did it end up having any effect on the engines temperature, or did you just like it better somewhere else. I was looking at doing a similar change to my Trooper and yours looked quite nice. I was also looking at placing a light bar where you have your wench, I do like the idea of a wench there much better.
I moved it because I thought it was creating a cooling issue. My Trooper started running hot. But when I removed it, it still ran hot. Turns out it was the radiator and fan clutch. The Trooper was so new to me that I didn't know the cooling was an issue beforehand. After removing it and installing a new grill, I gave up on the idea of putting the light back.
As for the winch location... it'll be a helluva lot easier to install a light in that bumper opening than installing a winch. It just depends on your needs and abilities to weld.
jc_in_az
Drives in Mud
Postby Carl747 » Wed Jan 25, 2017 4:32 pm
Ok, thanks a lot. I do think that I will be getting a winch at some point (once I get some more money), so I will probably be going with the grill lights.
By the way I love your Trooper build, I've been following it for several months now and it looks great.
Carl747
Postby matthew996 » Fri Mar 10, 2017 2:51 am
WOW! You have come a long way! I love the way it looks! - M
1994 Isuzu Trooper LS: Pretty much stock except for 3rd row seats
1995 Isuzu Trooper Limited: Diesel Conversion with 4JG2-TD engine (rebuilt prior to swap) from the U.K., stock otherwise (for now)
1992 Isuzu Rodeo (sold)
2004 Isuzu Ascender (sold)
matthew996
Has thanked: 27 times
Postby LookOut4TheYeti » Tue Mar 21, 2017 7:35 pm
Love how this think looks! I'm in mesa and have a 2nd gen rodeo and a jku wrangler. Maybe I'll see you out on the trails sometime :occasion5: Image
For this post the author LookOut4TheYeti was thanked by:
jc_in_az
LookOut4TheYeti
Postby jc_in_az » Tue Mar 21, 2017 7:47 pm
LookOut4TheYeti wrote:Love how this think looks! I'm in mesa and have a 2nd gen rodeo and a jku wrangler. Maybe I'll see you out on the trails sometime :occasion5:
Thanks! That would be cool. Our group has mainly stayed out near Wickenburg for the wheeling so far. Not sure what the summer will bring though. Only a couple of us have air conditioning. LOL
jc_in_az
Drives in Mud
Postby Doc » Thu Mar 23, 2017 8:15 pm
I love this thing
...4:19...you got a minute?
For this post the author Doc was thanked by:
jc_in_az
Doc
Postby LookOut4TheYeti » Thu Mar 23, 2017 9:06 pm
Lol yes first thing I did when I bought mine was fox the AC.
LookOut4TheYeti
Postby superman27344 » Sat Apr 01, 2017 7:33 pm
Lou
2000 Trooper aka "Brawn", 3.5 liter V6, 5spd
1989 Trooper aka "The Armadillo", 2.6 liter, 5spd SOLD
Carolina Isuzu Owners Facebook Group
Brawn Build Thread
The Armadillo Build Thread
"It has been my experience that folks who have no vices have very few virtues."
-Abraham Lincoln
Has thanked: 420 times
Have thanks: 75 times
Postby jc_in_az » Sat Apr 01, 2017 7:39 pm
superman27344 wrote:March 2017 ROTM Winner
SWEET!!! I never win anything! Thanks!!!
jc_in_az
Drives in Mud
Postby bradzuzu » Sat Apr 01, 2017 10:13 pm
That's awesome congrats !! Well deserved too :)
Previous
