My 98 Amigo/02 RS, "The Meego"
Re: My 98 Amigo/02 RS, "The Meego"
Postby egagnon086 » Fri Apr 07, 2017 9:37 am
I have a set of OEM dual fans from a 02 Rodeo sport I took the body from, along with all the wiring harness, relays, and fuses to make it work. It looks to just bolt up to the radiator on the engine side, I just need to remove the engine fan to make it fit. I just didn't know if there was any significant improvement, ive never acutally had a cooling issue with the current fan, but it is starting to stay engaged at lower temps. I've powered them on with a spare battery, they put out some serious juice, not sure of the amp draw but the fuse is 30 amps.
I may experiment, I was thinking using a temp switch to turn on one fan when it hits ~190 deg, and then use the A/C relay to turn on the other fan. And maybe wire in hard switches to just turn them on and off manually.
egagnon086
Has thanked: 51 times
Have thanks: 87 times
Postby lorenzo816 » Fri Apr 07, 2017 9:57 am
Yeah thats it.
sorry my memory fuzzy sometimes.
I must be thinking of the trans fan on the front.
lorenzo816
Has thanked: 81 times
Have thanks: 52 times
Postby egagnon086 » Fri Apr 07, 2017 6:55 pm
Anyone have any good ideas for mounting a 60" hi lift? I was thinking about clamping on the bull bar or making brackets and bolting to the rear door by the hinges.
egagnon086
Postby egagnon086 » Tue Apr 18, 2017 9:26 am
Spring Beasley Knob trip was a great time. I even had to use my winch this time. but nothing could stop us. See more pics of the GA Zu Cru on this thread:
viewtopic.php?f=9&t=105377
But I will post my Gratuitous Poser shots here.
Finally up top, They have done some major trail work here, the top of the mtn in completely changed, be a great camp site.
While on top, the mtns micro weather patterns set in and it started pouring, it made things way more interesting on the way out.
egagnon086
Postby ZuminaZX » Wed Apr 19, 2017 9:16 pm
How did the locker work out?
2004 Rodeo 3.5 DI
ZuminaZX
Have thanks: 22 times
Postby egagnon086 » Wed Apr 19, 2017 9:36 pm
The rear locker works much better this time around, I think the guys who installed it when they did my gear set up put it in wrong. It's not hard to do on this powertrax model, I put it together on the bench 4 different ways that would fit in the carrier but only 1 way is correct. I stayed locked, I even did alot of the trail in just rwd. It's a twisty trail so the locker up front hinders my steering Abit. It's nice to be able to switch it off and still have a locked rear to push me up and over. I did use my winch on one rough apot, it was about a 2-3 ft rock ledge. I made it up under my own power but used the winch line to keep from rolling backwards. I'm extra cautious now, I don't want to be on my roof again...
The only issue I had was the tight twisty MTN roads to get there were not much fun with locker pushing me when it reengaged after a turn. After While I got use to it, did alot more coasting then driving in a turn. But id say as long as this one doesn't break it's gonna stay in the rear.
egagnon086
Previous
Users browsing this forum: Google Adsense [Bot], paulevans76 and 3 guests
