My 98 Amigo/02 RS, "The Meego"
Re: My 98 Amigo/02 RS, "The Meego"
Postby egagnon086 » Tue Sep 06, 2016 9:33 pm
That's a good idea, I didn't think of that. I'll just paint the fender flares to match. I kinda like the "bright work" look it has. My plan is to see how I like it then powder coat it that color or close.
I think flat black looks weird on the gloss black body, and if they are gloss black on gloss black they don't really stand out at all. Things were so much easier when it was an orange truck.lol.
Toccoa, you have a plan on installing those gears and LSD? I need a wheeling partner for the fall.
egagnon086
Has thanked: 57 times
Have thanks: 98 times
Postby Toccoa » Tue Sep 06, 2016 10:00 pm
I'm with you on the pitfalls of the all black look. Should have held out for an orange Amigo body. :lol:
If you go for the brightwork look, here's an idea for the front bumper. It would take some of the visual weight off of the front by blackening out the middle.
2002 Rodeo Amigo Sport
V6 Auto RWD
Currant Red Mica Lagoon Blue Matte Metallic Thundercloud Metallic
1" Wheel Spacers
General Grabber AT2 255/70/16
1" Suspension Lift (coil spacers from Indy4X)
Build Thread Vinyl Wrap Samurai
Toccoa
Has thanked: 67 times
Have thanks: 52 times
Postby Toccoa » Tue Sep 06, 2016 10:10 pm
egagnon086 wrote:Toccoa, you have a plan on installing those gears and LSD? I need a wheeling partner for the fall.
LOL. Gotta save up the cash first. That new cat was a painful blow to the wallet. :shock:
I could probably do some Ranger trails. :lol:
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby egagnon086 » Wed Sep 07, 2016 7:29 am
We should be able to do it all on a dry day, Besides I got a winch and a tow rope.
For this post the author egagnon086 was thanked by:
realbigcountry
egagnon086
Postby egagnon086 » Fri Sep 09, 2016 10:16 am
So, I sold my Calmini track bar to a fellow planet member (Nislo) and going to make my own link. What I know the calmini bar is 1 1/8 thick, I'm planning on making my new bar out of 1" tubing with .25 thick also going to make it adjustable with poly bushings and grease zerks.
egagnon086
Postby egagnon086 » Wed Sep 21, 2016 9:27 pm
Got my new track bar done today, gonna paint and then install tomorrow. I'll post some pics after its all installed.
Also I made my own steering spacer for my intermediate shaft, I trust my welds ok but not really on steering bits. The spacer should work just a good and it can just come out if I need it too.
I may need to trim some of this inner fender abit, as it just scrubs on the tire when turned to full lock and its flexed up. Definitely need to trim abit if I get bigger tires.
egagnon086
Postby egagnon086 » Mon Sep 26, 2016 10:14 am
Some updates completed.
didn't like my welding so I made a steering ext from some Al. works great. If anyone needs one let me know.
Here is a pic of my new longer adj. track bar.
Also got my CB installed, with firestick. And some d-rings on the updated rear bumper.
I was having issues still with tires rubbing so I hacked the backside of the front fender for more flex room.
egagnon086
Postby totten » Mon Sep 26, 2016 10:10 pm
Looks great. Like the steering ext. you made,Nice mods, I'm running a little will ant. on my C.B. Thanks for pics. and helping other members here.
For this post the author totten was thanked by:
egagnon086
totten
Have thanks: 85 times
Postby egagnon086 » Tue Sep 27, 2016 1:59 pm
Thanks, It's a constant work in progress.
I also ended up bypassing the factory Alarm system, it kept going off at 3 in the morning for some reason. I hardwired it and removed the box. If anyone wants to know how, let me know its not difficult.
egagnon086
Postby Toccoa » Tue Sep 27, 2016 10:02 pm
Man, I just saw Meego in person and it already looks different. :lol: Look'n good. Needs bigger tires. 8)
That's crazy about the alarm. Maybe Meego is rejecting its new body. :shock: :twisted:
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby egagnon086 » Mon Oct 03, 2016 9:07 am
So I got my HD lower links installed and adjusted, the oems were a pain to get off, had to visit Jerry and use his 3/4 drive impact.
Here are my new HD greaseable and adj lower links.
All links installed with adj, track bar:
Also, I got some 2" wheel spacers to play with, may try out some 315/75s
egagnon086
Postby Toccoa » Tue Oct 04, 2016 6:59 pm
Niiiiiice! 8) Def need some bigger tires to fill out the wheel well. Those HD lower links look awesome.
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby egagnon086 » Tue Oct 04, 2016 7:06 pm
Thanks, If anyone wants info on the HD Links let me know, they were quite affordable and I have my invoice numbers to reference if you think you may want a set.
egagnon086
Postby egagnon086 » Mon Oct 17, 2016 1:20 pm
Here are some pics with the 2" wheel spacers, they aren't too obnoxious. I still think some bigger tires would be nice.
egagnon086
Postby Toccoa » Mon Oct 17, 2016 9:34 pm
egagnon086 wrote:Here are some pics with the 2" wheel spacers, they aren't too obnoxious. I still think some bigger tires would be nice.
33's? :twisted: :twisted: :twisted:
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby ZuminaZX » Tue Oct 18, 2016 12:04 pm
33x10.5x15! Looks good boss, you need to hit that solenoid cover with some semi gloss!
2004 Rodeo 3.5 DI
ZuminaZX
Have thanks: 24 times
Postby egagnon086 » Tue Oct 18, 2016 12:36 pm
I was thinking of hitting it with something and then putting a Isuzu badge from a 1st gen trooper on it. Seeing the stock one is hidden behind it., some 255/85s or some 295/75s would work.
Anyone need a good set fo 265/75-16 cooper disco at3s?
egagnon086
Postby Toccoa » Tue Oct 18, 2016 9:56 pm
Here is jwood's Amigo with 33s.
viewtopic.php?f=30&t=67852
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby egagnon086 » Tue Oct 25, 2016 11:27 am
Looks nice, That's with 285/75s I think. I like the look, may try some 295/75s if I can find them cheap enough.
egagnon086
Postby superswire » Thu Oct 27, 2016 4:28 am
Do you think 33x12.50 would rub ? I have brand new ones on mb razors as well as a set of flakes. They are on my vx but I may be willing to do some trading or something depending what you have for my rodeo if you want to pm me. Awesome thread. I'm very inspired now about the 99 rodeo I just got now !!!
1999 vx, (the unnamed one) magnaflow, k&n drop-in, ome coils, 2" diff drop, rancho 9x, Darlington bump stop extensions, tones hidden hitch, reese basket on facory Yakima bars, mb razors w/ 33x12.50 Hercules M/T. (Currently undergoing a heart transplant because she seized up on me)
1999 rodeo ls (the shepherd of fire) low mile engine swap (3.2), mua5, Moog cc784, Reese basket, 32x11. 50 KUMHO M/T on snowflakes, ARB bumper, badlands 12k and some stickers !
Past zu's: '92 migo, '95 troop, '93 rodeo, '97 passport.
superswire
Has thanked: 31 times
Have thanks: 5 times
Postby egagnon086 » Mon Nov 07, 2016 5:07 pm
Well, I made it up to Uwharrie on Saturday, just to have to turn back home and take care of some family matters. It was a long 10 hrs in the car, for a small meet and greet with the guys and some light duty trail riding. I did pick up a new top I got earlier, Thanks again Superman.
I snapped acouple pics before I left.
When I drove up to meet everyone, I saw Ssiggys Amigo and I was having horrible flashbacks and started getting tired just thinking of all the work that needed to be done. I don't know what it is, 2nd gens love ending up on their roof, Cronk, Me, and now Ssiggy. Glad no one was hurt badly, but it does suck. Makes a good story though.
I plan on doing this again in the spring, maybe we can meet up closer to home and try some trails in North GA before the end of the year or before spring Uwharrie.
Made it home with a new to me top and some extra Zu goodies. Even parked in the grass, just because.
egagnon086
Postby superswire » Tue Nov 08, 2016 12:54 am
Dude I saw your amigo and wanted so bad to come check it out but I was having some differential issues and had to run to Troy for some lsd additive you better come up in the spring I'm trying like all heck to have the vx on 35s and the rodeo on 33s by spring :)
superswire
Postby egagnon086 » Mon Dec 05, 2016 2:05 pm
Went for a drive in the N. Ga woods last weekend. It was a blast, Just me a older Toyota truck made it. It had some tricky trails. I'll have to add it to my normal route in the mtns for sure. I got some pics, some posted below, and videos that I'll post on you tube after some editing for length.
Near Suches GA
You can see a smallish ledge on the "wall" where my tires was driving, before it slipped down.
To get up I had to drive into the "wall" abit to keep the tires planted, I got to one spot with a lot of wet leaves on it and the wheel slipped and luckily my mirror was in or else it would of broken off. driver wheel was in a 3 ft rut compared to the passenger side.
A lot of creek crossings here, washed a lot of mud off
Definitely need a locker to get up most of they hills and as much axle clearance as possible. It really made me wish I still had the locker in the back and I will be wishing for some wider tires for sure, and M/Ts.
superswire
egagnon086
Postby totten » Mon Dec 05, 2016 11:34 pm
Looks like fun! Nice job on Amigo/RS bumpers,winch setup. Yes a locker and MT's added would help at hills. In time you will have,thanks for pics. 8)
totten
Postby egagnon086 » Tue Dec 06, 2016 8:17 am
I have a front aussie locker and my rebuilt Trac loc got me up this hill. The guys who rebuilt the trac loc said they added an additional washer in it to get it to "lock better". It seemed to stay locked pretty good, under power I can chirp my tires. I actually stuffed my front wheel at one point over a boulder, I didn't even recognize what it was at first. The top of my tire to any part of the wheel well is almost 8 inches. I wish I could of gotten a pic of that.
I think maybe for tax time looking at a rear locker, better shocks, 33X12.5 or better MTs. I will need a clutch sooner rather than later, and my Revos installed. Paging Lorenzo...
If anyone is around N. GA and wants to go wheeling sometime let me know, we have some great trails and forest rds. I'll show you around.
egagnon086
