Zumina's 04 Rodeo DI
Postby ZuminaZX » Mon Apr 15, 2013 12:43 am
I should stop cluttering up the "what did you do to your isuzu this week" thread. I'll flesh out the details later but here are some before and after shots:
2004 Rodeo 3.5 DI
ZuminaZX
Have thanks: 22 times
Re: Zumina's 04 Rodeo DI
Postby clipper 03 rodeo » Mon Apr 15, 2013 9:53 am
Looks great man!
NEW - 2016 GMC Sierra All Terrain
NEW- 2017 Jeep Renegade Latitude 4x4
TRADED IN -2004 Clipper Blue Isuzu Rodeo - 3.5L DI - Aisin Auto Tranny - 3" Lift, Calmini Upper Links, Skyjacker Shocks (extended rears), 32" Procomp AT Tires, OEM 15" Snowflakes, Headlight Projector Retrofit, Bull Bar, ect..
TOTALED =( -2003 Clipper Blue Isuzu Rodeo
clipper 03 rodeo
Has thanked: 21 times
Have thanks: 71 times
Postby Ekholm1997 » Mon Apr 15, 2013 10:27 am
^^^ Ditto. Love the lift, wheels and roof rack. Nice work!!
1997 Isuzu Rodeo 4WD
3.2L 6VD1, 5-speed , 3" Suspension lift, 1" Body lift, 33X12.50-15 Dick Cepek Mud Countrys, Vision "Soft 8" 15X8 wheels, Superwinch Premium hubs, DuraSolid Mini-Spool, Flowmaster exhaust, AG flood lights, Trail Rated badges, custom painted tow hook.
Build thread http://forum.planetisuzoo.com/viewtopic.php?f=15&t=59551
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
WOW--What a Ride!
"One day, your entire life will flash before your eyes, make sure its worth watching!!"
Ekholm1997
Has thanked: 24 times
Have thanks: 40 times
Postby 94Rodayo4x4 » Mon Apr 15, 2013 7:04 pm
I really like this Rodeo. Wish I could have found a clean low mileage DI when I was car shopping. :|
Taylor H.
1994 Isuzu Rodeo S, MUA5, 4WD, V6, 31's- Sold :( Rest In Peace, Ticking Green Beast!
2000 TOYOTA 4Runner SR5, V6, Auto, 4WD
1.5" Lift, 265/75 Yokohama Geolandar A/T, PIAA 520's, 22" LED Light Bar, Flowmaster
Isuzu Parts for sale
94Rodayo4x4
Has thanked: 32 times
Have thanks: 47 times
Postby ZuminaZX » Mon Apr 15, 2013 8:36 pm
super-bright LED plate and reverse lights:
Still need to do some more trimming:
I'd like to keep the running boards...
2004 Rodeo 3.5 DI
ZuminaZX
Postby ZuminaZX » Mon Apr 15, 2013 8:50 pm
before:
after:
2004 Rodeo 3.5 DI
ZuminaZX
Postby clipper 03 rodeo » Mon Apr 15, 2013 8:52 pm
It's amazing how some simple things can totally change the look of a vehicle. I was looking at some pics of my Rodeo stock and how it is now and it looks like a whole different vehicle even though there isn't too much that changed.
I'm really digging the window visors, I may have to get a set for my 00 Rodeo. :D
clipper 03 rodeo
Postby ZuminaZX » Mon Apr 15, 2013 8:57 pm
clipper 03 rodeo wrote:It's amazing how some simple things can totally change the look of a vehicle. I was looking at some pics of my Rodeo stock and how it is now and it looks like a whole different vehicle even though there isn't too much that changed.
I'd really like to add a hood scoop or heat extractor with a molded-in, flush finish. I have a body/paint guy that I'm sure would be willing to try but I'm not sure which scoop kit would fit best.
2004 Rodeo 3.5 DI
ZuminaZX
Postby ZuminaZX » Mon Apr 15, 2013 10:31 pm
hard-wired tranny temp gauge for constant illumination when on, it's very, very bright
2004 Rodeo 3.5 DI
ZuminaZX
Postby ZuminaZX » Tue Apr 16, 2013 11:43 am
Have to show my Red Sox and Indy4x love:
2004 Rodeo 3.5 DI
ZuminaZX
Postby recon » Tue Apr 16, 2013 11:52 am
:D wow looks great,how much lift did you get,your ride look super clean 8) recon
1995 isuzu 4x4 pickup|2.6 4cyl|5spd|3 inch body lift|2.5 inch suspension lift|33 inch treadwright wardens|indy4x hd tie rods|custom winch mount|12000 lb winch|extreme high lift jack|off road lights|front and rear aussie lockers|1.5 inch diff/crossmember drop|sway a way hd torsion bars|jeep trail rated badge|moog ball joints|moog center link|precision cv axle boots|optima battery|skyjacker steering stabilizer|tinted windows|bedliner|window rain guards|Indy4x braided brake lines|indy4x sway bar bushings|exedy daikin clutch kit|revolution 3.07 transfer case gears
Build Thread: http://forum.planetisuzoo.com/viewtopic.php?f=15&t=53703&hilit=evolution+of+my+truck
recon
Has thanked: 109 times
Postby ZuminaZX » Fri Apr 19, 2013 10:22 pm
Wheeled a little with my brother this evening:
I need to trim just a tiny bit more off of the running board corners as they rub under compression/full lock. I was able to completley flex/stuff the tires without and clearance issues.
2004 Rodeo 3.5 DI
ZuminaZX
Postby ZuminaZX » Tue Apr 23, 2013 9:07 pm
whelp, that lasted all of 40 days:
its replacement will have a clear piece of vinyl applied to its lens to prevent this
Also, my alternator decided to die about a block from home this evening....then I broke my CB antenna on a branch in the driveway.
2004 Rodeo 3.5 DI
ZuminaZX
Postby gear60 » Thu May 02, 2013 4:28 am
Hi,
Very nice of izu.
gear60
Trail Rider
Has thanked: 16 times
Have thanks: 9 times
Postby dustinGERSTEL » Sat May 04, 2013 11:49 am
Looks awesome! I like the axiom wheels.
dustinGERSTEL
Postby Turbokidd » Sat May 11, 2013 11:22 pm
Hey Zumina, what bulbs did you replace your reverse lights with?
Thanks!
Turbokidd
Postby ZuminaZX » Sun May 12, 2013 6:58 pm
Turbokidd wrote:Hey Zumina, what bulbs did you replace your reverse lights with?
Thanks!
Cree LED versions of the originals.
A few Moab pics:
2004 Rodeo 3.5 DI
ZuminaZX
Postby ZuminaZX » Tue May 14, 2013 1:20 pm
Ordered ARB diff cover, Calimini bent links, track bar, and cross member, and OME 919s to replace my troop springs an spacers. I'm going to have all the suspension components powdercoated white when they arrive and the ARB cover PCed with clear coat (the nodular iron rusts quickly).
I'm still curious about a hard-wired iPod interface with the OEM deck. I think the system as-is both sounds and looks great so I'd like to avoid a gaudy aftermarket head unit.
2004 Rodeo 3.5 DI
ZuminaZX
Postby ZuminaZX » Tue May 14, 2013 1:27 pm
Here are some more mod/build pics from the other thread:
Sick-Speed horns (not super loud, but definitely louder than stock)
The brackets aren't entirely symmetric due to using existing holes in the hood latch support bracket. I also had to clearance the AC fan shroud and grill. There's also a large transmission cooler hiding in there on the driver's side.
Of course, I gave all the bits behind the grill a nice coating of gloss black first:
Troop springs, Daystar spacers, SJs, and 1.5" wheel spacers:
I hid the bar light switch here to avoid unknowing/unwanted activation:
Cipa Auto dimming/map lights/compass/temperature rearview, awesome addition!
2004 Rodeo 3.5 DI
ZuminaZX
Postby ZuminaZX » Tue May 14, 2013 1:42 pm
here was the highest observed tranny temp:
this was while climbing soldier's summit on highway 6 on the way to Moab with the cruise control set at a GPS 65 (speedo is underdriven by larger tires) in 3rd gear. Truck was lightly loaded inside, had a 300lb motorcycle on a 30lb hitch-hauler on back, and, of course, the additional drag of the roof basket/spare/other accessories. I averaged 23mpg on the way there, not sure about the way back (haven't refilled yet).
2004 Rodeo 3.5 DI
ZuminaZX
Postby dustinGERSTEL » Fri May 17, 2013 8:47 pm
Looking awesome, keep it up!
dustinGERSTEL
Postby jwood1016 » Tue May 21, 2013 4:08 pm
Awesome truck.
John
2002 Trooper
3 inch lift and 33's
jwood1016
Have thanks: 18 times
Postby ravi261 » Mon May 27, 2013 8:06 pm
ZuminaZX wrote:Ordered ARB diff cover, Calimini bent links, track bar, and cross member, and OME 919s to replace my troop springs an spacers. I'm going to have all the suspension components powdercoated white when they arrive and the ARB cover PCed with clear coat (the nodular iron rusts quickly).
If the radio was made by Fujitsu, the OEM Toyota interfaces will work (mine is for a 4runner). But I have come across newer than 2000 OEM Isuzu radios that were made by Alpine. I think the ones made by Alpine had the Alpine proprietary cable on the back that you can find ipod adapters for.
1999 3.2 V6 4wd Rodeo LS 178k 4L30-E
For the 1st time since 2006, everything works! (including ABS :) )
ravi261
Has thanked: 2 times
Have thanks: 67 times
Postby ZuminaZX » Tue May 28, 2013 3:05 pm
Thanks the for the info! I will pull it out and see what I can find!
2004 Rodeo 3.5 DI
ZuminaZX
Postby ZuminaZX » Wed Jul 24, 2013 3:13 pm
I changed my mind on the ARB cover since it weighed in at a stately 37lbs and was probably much more than I needed. I really just wanted something stronger with a drain plug. The aluminum construction should also help dissipate heat. I ended up going with a super thick cast aluminum G2 cover then having it powdercoated red:
all of my suspension components are still at the PC shop, one of those fast, cheap, and quality: pick two deals. It looks like next weekend I'll spend a majority of a Saturday under the truck putting all of these goodies on. Now I have my eyes on a set of those slick hood vents from rocky road outfitters....hmmmmm.
2004 Rodeo 3.5 DI
ZuminaZX
Users browsing this forum: Google [Bot] and 3 guests
