2001 trooper build/diesel swap
Re: 2001 trooper build/diesel swap
Postby foytiX » Mon Jan 14, 2013 9:18 am
onebadtrooper wrote:Image
sorry, had to wipe the drool off my chin :lol:
'90 trooper 2.6 MUA 3" BL 33's, 5.38 gears, 12 bolt locker, and more http://forum.planetisuzoo.com/viewtopic.php?f=15&t=499
'94 Trooper MUA "theBeater"....http://forum.planetisuzoo.com/viewtopic.php?f=15&t=67019
'94 trooper ls.....parts and engine donor
'95 trooper limited.....1" hockey puck lift http://forum.planetisuzoo.com/viewtopic.php?f=15&t=66472
'98 trooper.........parts and trans donor
foytiX
Has thanked: 74 times
Have thanks: 86 times
Postby WhiteEightBall » Thu Feb 07, 2013 11:16 am
When I move overseas I may end up doing this swap with my Trooper. That or say screw it, sell my trooper over here, and buy one over there that's already a Diesel.
Amazing build and extremely informative. I now know what needs to be done in order for this build. All in due time though.
I love the '01 man. Good work. Everything looks stock-ish. I love that look.
Wish I could put a RTT on MY Trooper.... ARB told me it's a no go on the 96...
My Garage
Youtube junks
I also have a streetfire account. Just search for username whiteeightball.
WhiteEightBall
Super Trooper
Postby tacomazach » Mon Feb 11, 2013 1:13 pm
Could you possibly post some more information about the supplier of your 4JG2TC 3.1? I'm having a crappy time trying to find one for myself.
tacomazach
Postby Dieterbuilt » Thu Mar 07, 2013 1:26 am
I bought mine on e-bay runs good.. I think I payed $2,600 for it. Complete engine trans t-case wiring harness,but it is a auto.
Dieterbuilt
Postby trevtastic » Wed Apr 10, 2013 11:02 am
tacomazach wrote:Could you possibly post some more information about the supplier of your 4JG2TC 3.1? I'm having a crappy time trying to find one for myself.
IDK if you're still looking, but here's a good deal on a Japan Low-Mileage Motor & Transmission.
I wonder if this swap is possible in a 97 Rodeo? *Making note to do research*
trevtastic
Have thanks: 5 times
Postby matthew996 » Sat Apr 20, 2013 1:23 am
Wow!!! I like 'em! I also have a family of Isuzu's. I just went through a diesel swap with my '95. I bought it with the conversion already done, but while my parents were driving it out from Arizona to California, it lost oil pressure and spun a bearing and scored the crankshaft. After months of trying to find all of the parts, I could not find the crankshaft that would for sure fit my 4JG2 TD. I ended up ordering a "new" '94 4JG2 TD block from the UK. After more than a year, it is running.
I would love to pick your brain sometime if you don't mind. My mechanical skills are still being honed. I am trying to get some of the electrical bugs worked out (i.e. tachometer hooked up, glow plug pre-heater wired to the ignition, etc).
1994 Isuzu Trooper LS: Pretty much stock except for 3rd row seats
1995 Isuzu Trooper Limited: Diesel Conversion with 4JG2-TD engine (rebuilt prior to swap) from the U.K., stock otherwise (for now)
1992 Isuzu Rodeo (sold)
2004 Isuzu Ascender (sold)
matthew996
Has thanked: 27 times
Postby onebadtrooper » Sat Apr 27, 2013 2:40 pm
Thanks, mine is still a work in progroess for sure. I don't have my tach hooked up yet but will hopefully figure that out soon. The glow plus I just have wired to a push button using a ford starter relay.
Lately I've been tackling little small projects. Here is a list below, I'll try to get some pics..
Connected "High Idle" switch using a factory cruise switch and a vacuum solenoid left over from the 3.5.
Bought and installed autometer EGT.
Came up with a different trans mount and engine mounts, she's smooooooth now :mrgreen:
Got all factory gauges working, with the exception of the tach.
Found some paint that matches the factory tan color (flat dark earth gun paint) and repainted gauge pod.
That's all i can think of now, I'm sure there is more I can't think of. I've been daily driving it for almost a year now.
_Chris..
89 trooper, 6"lift, 35x13.50R15 baja claws, tera low 3.07's and 5.38's.custom bumper F&R, built 3.4L,safari snorkel.
93 trooper s SOLD..
2001 trooper 3.1L turbo diesel conversion ,yokahama geolander a/t's 265x75r16, ARB bull bar. 2wd to 4wd conversion, rock sliders, ARB roof rack with IPF lights, ARB front locker.
two troopers in a family of isuzu's
onebadtrooper
Postby onebadtrooper » Sat Apr 27, 2013 2:49 pm
At the end of this month my inspection was due. So this morning I took her over to the inspection shop to see what they say. I told the guy I have converted my truck to diesel, he said no problem and asked if it had diesel in it now. I said yes and he open the gas cap and smelled the diesel, then went on with the inspection.... only $14.50 and I'm good to go. I can't believe it was that easy!!!!!! I've been stressing for a year about this...
93 trooper s SOLD..
onebadtrooper
Postby mtman » Sat Apr 27, 2013 2:59 pm
Cool. Move to Montana and if your vehicle is 11 years old or more you can buy a permanent tag and you're done.
1995 Isuzu Trooper S PEP
Motor: 3.2 DOHC Conversion, Multec 2 Injectors, A/C Fan, Drilled Out Exhaust Limiters, NGK Ignition Wires
Electrical: Group 27 Battery, 2 Gauge Battery Cable Conversion with Military Style Clamps, Load Boss 165A Alternator
Trans/tfer: AR5 Swap viewtopic.php?f=22&t=72724 3.07:1 Transfer Case gears. 6X20 Speedometer Gear. CR: 65.31:1
Diffs: 5.38s, Solid Pinion Spacers, viewtopic.php?f=22&t=66722, Powerbrute LSD F/R, viewtopic.php?f=22&t=66739
Driveline: Aisin Hubs, GMB HD U-joints greasable front and rear, Drivetrain Plus balanced and trued driveshaft
Suspension: OME Medium 912 Coils, OME Heavy Shocks, John's 1.5" Custom Diff Drop, DC Built Low Profile Front Crossmember, Ball Joint Flip, Indy 4X HD Tie Rods
Tires: LT285/75/R16E Goodyear Wrangler Duratrac on stock Isuzu Alloys
Recovery: ARB Bullbar, Warn M8000, Off-road lights
Accessories: Counteract Electrostatic Rust Prevention, Yakima Wingmaster Crossbars with Loadwarrior basket, Stainless Steel Hitch, Little Passenger 3rd Row, OEM compass, Overhead DVD, and heated seats
[b]Looking for used/cheap:
ARB Roof Rack and/or Mounts
mtman
Have thanks: 16 times
Postby bradzuzu » Sat Apr 27, 2013 3:09 pm
Wow that's was to easy :) ... I'm glad it's still runnin strong !! Any new pics or adventures with it ??
Has thanked: 214 times
Have thanks: 375 times
Postby onebadtrooper » Sat Apr 27, 2013 3:19 pm
Yeah it was way easy!! Not much new pics, mainly just daily driving lately. I've got a few I'll post up. Hopefully before it gets too hot I'll take it out camping...
_ Chris..
93 trooper s SOLD..
onebadtrooper
Postby Richey » Sat Apr 27, 2013 7:10 pm
What millage are you getting with that 4JG2-T? Do you know the estimated 0-60?
-2000 Rodeo 4x4 3.2 Build
-1990 Spacecab 4x4 4 speed 2.2L Diesel Complete Veggie oil conversion Build
-1989 2.6L Amigo 4x4
-1984 2.2L Diesel P'up
Richey
Have thanks: 7 times
Postby reran » Sun Apr 28, 2013 5:36 pm
onebadtrooper wrote:At the end of this month my inspection was due. So this morning I took her over to the inspection shop to see what they say. I told the guy I have converted my truck to diesel, he said no problem and asked if it had diesel in it now. I said yes and he open the gas cap and smelled the diesel, then went on with the inspection.... only $14.50 and I'm good to go. I can't believe it was that easy!!!!!! I've been stressing for a year about this...
Chris,
Just finished the conversion a few weeks ago and I'd, also, been dreading going to the Tag Office (for over a year) to title & register my 89 and find out what I had to do. So a week before the URE trip, I arrived at the Tag Office, title and check book in hand to find out what kind of maze was awaiting me. The lady at the window took my paperwork and while she was examining it, I explained it has been converted to diesel... her face glazed over and she gave a big sigh. Then a couple minutes later she handed me my new plate and advised she changed the fuel type from Gas to Diesel and infomed me the new title will be mailed to me within a couple of weeks. No inspection, no verification, no emissions, no nada. That was it! Talk about EASY! I had the biggest grin walking out of a government office astonished at how fast and easy it was. No emissions testing ever again for this Trooper. I LOVE IT! I understand your joy. :mrgreen:
Leland
"As slowly as possible, as fast as necessary."
"Do what you can, with what you have, where you are." Theodore Roosevelt
89 Trooper, 2.6L Turbo, AW 30-80LE
90 Spacecab LS 4wd, 2.6, 5spd
94 Trooper SE, 3.2 DOHC
Image Image
reran
Has thanked: 8 times
Have thanks: 24 times
Postby electricpuppyboy » Mon Jun 03, 2013 12:05 pm
Chris,
This is a great build. I just read through the whole thread again this morning. Good work!
-Bob
Image Image Image Image
1988 Trooper LS 4ZE1 mua5 - "Build" Story
1990 Trooper S 4ZE1 mua5 - Being parted out - click for parts
1989 Trooper RS 4ZE1 Auto - gone
1989 Trooper LS 4ZE1 Auto
electricpuppyboy
Has thanked: 28 times
Have thanks: 43 times
Postby farron » Mon Jul 01, 2013 9:07 pm
onebadtrooper wrote:Well i've put about 1200 miles in it. So far so good. I bought a tool to adjust me injection timing, it was .010 advanced. It runs really good now, a bit longer to start with no glow plugs after adjusting the timing.
Had a custom exhaust made up on friday, i told them how i wanted it run the same way as factory but they ran the exhaust down the passenger side. They did a good job so no worries. I went with a flowmaster and 2.5" pipe, she is nice and quite until you step on it.
I'm getting a quote for a diesel dash cluster with diesel tach. Also getting fuel filler kneck, fuel filter housing with pump, and glow plug computer.
Did you advance your timing more or retard it and were did you set it at?
More to come....
farron
Postby rabidrabbit001 » Tue Aug 26, 2014 11:26 pm
Hi,
my name is Dan and I am about to do this same 4jg2 5 speed manual swap. My Trooper is a 1999 3.5 with a 5 speed manual. I am interested to know how all the transmission wiring swaps over ie transmission speed sensor and also the tach and how you got the other stock gauges (fuel, temp, oil psi) working. Please anyone is welcome to respond if you have legitimate wisdom to pass on. This is a rock and roll swap thread. thanks a lot.
rabidrabbit001
Postby onebadtrooper » Thu Jan 07, 2016 6:30 pm
I just wanted to give a little update on this after 2-3 years. The trooper is still doing awesome, its driven daily. The diesel has never skipped a beat!!! couldn't be more happy with it. I've since got married, bought a house and have a 5 month old so the projects have slowed down quite a bit.
93 trooper s SOLD..
onebadtrooper
Postby hessmess » Thu Jan 07, 2016 7:46 pm
Sounds like a completely different set of projects to me! Congratulations!
88 Trooper (recycled)
viewtopic.php?f=15&t=81567
viewtopic.php?t=55081
hessmess
Have thanks: 145 times
Postby bradzuzu » Thu Jan 07, 2016 10:19 pm
Sounds great !! Congrats man !!
Also it's good to hear from you :)
Postby Warrior_22 » Tue Apr 26, 2016 9:46 pm
OneTroop you still around?
I was wondering if you put anything in the fuel system to send fuel the the mechanical pump, since you removed the gas in-tank pump and put a straw in there lol... Seemed like a long way to draw fuel from the tank/strainer? through filter, 12-14ft of line to the pump? Does it really draw it that far?
Also, what about your drivetrain (axles) My rear axle looks too long and front too short, what did you do to solve that one? TIA
Warrior_22
Postby rabidrabbit001 » Tue Apr 26, 2016 11:08 pm
I'm not speaking for "OneTroop"....but am answering since I did the 3.5L gas to 3.1L diesel swap. Yes the injection pump is the only pump needed to pull fuel from the tank. I used 3/8" line from rear to front and ran it directly into the tank through the gas sending unit cap lol...... not a long way at all. Be sure to use a water seperator with a prime pump on it.....as this will aid if you ever run out of fuel or need to reprime after injector /pump work has been done. As to the (drive shafts/prop shafts lengths) the rear one has to be shortened by a drive shaft shop. The front one will work just fine as is.
rabidrabbit001
Postby Warrior_22 » Wed Apr 27, 2016 12:08 am
I built a large spin-on filter mount setup under the chassis in front of the tank that I can put a water-sep style filter on, but it doesn't have a primer pump on it. Ill have to look into that, good idea. Another about the fuel system, pressure relief/return line. My mechanical pump has the larger inlet? on the front (towards the front of motor, and what looks like the return outlet (1/4") on the back? Is that a return outlet? And this stop solenoid, that has to stay hot to stay open yes? Both wires, one? The other gets? TIA
Warrior_22
Postby humming » Mon Jun 20, 2016 1:28 am
Very cool build. How heavy is the roof top tent? I assume it's a 2-person affair to get it on and off?
1990 4runner - totaled
1991 4runner - sold
2005 mazdaspeed miata - sold
1973 datsun 240Z - perpetual project
1997 Trooper: http://www.planetisuzoo.com/viewtopic.php?f=15&t=87699
humming
Postby rmfurr » Sun Apr 16, 2017 1:11 pm
Wow this is a great thread! I am just finishing up a 4GJ2 conversion on a 2001 Trooper as well and this thread has been a great resource and inspiration. Did you ever get a chance to test the towing capacity? I'm wondering if I'll be able to pull a decent sized(4000-5000lb) travel trailer behind mine.
2001 Isuzu Trooper LS - 4WD - 4JG2 Diesel Conversion
rmfurr
Previous
