89 Isuzu Pup
Re: 89 Isuzu Pup
Postby hessmess » Mon Jul 06, 2015 10:07 pm
After getting home from camping I managed to get really sick for 5 days and didn't even look at the truck. Took a look tonite and the hood opened up with no problem. The biggest problem will be getting the headlight back in alignment and finding a replacement grill but it will work fine for now. Bumper is pushed back a bit but not bent. Front corner of the hood is bent and so is the fender. but again, not bad. Something that seemed to of happened at the same time is the trans/tranfercase started leaking bad. I have to pull the skid plate off and take a look. I hope to get that done tomorrow if I don't have to do OT at work.
88 Trooper (recycled)
viewtopic.php?f=15&t=81567
viewtopic.php?t=55081
hessmess
Has thanked: 8 times
Have thanks: 141 times
Re: 89 Isuzu Pup
Postby squatch » Tue Jul 07, 2015 12:36 am
It's an excuse to put the wide 'Migo fenders on it!
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 66 times
Have thanks: 326 times
Re: 89 Isuzu Pup
Postby hessmess » Tue Jul 07, 2015 8:54 pm
If I had 'Migo fenders that might be an option. A few years back I picked up a fender off a Rodeo, but it is bright blue and I don't have the funds for a repaint. So we will see what happens. Didn't get a chance to do anything tonight, worked 3 hours over and then it was raining. I think I will just wait for the weekend.
hessmess
Re: 89 Isuzu Pup
Postby tbecktold » Wed Jul 08, 2015 5:12 pm
I had planned to do Amigo fenders and rear quarters on it, and even went as far as to draw cut lines on an Amigo at the junkyard. The last time I was out there, the Amigo was still there, still with nothing removed (except the tailgate, Sean got that).
I've downgraded to just lusting after regular cab 4x4 Pickups.
tbecktold
Re: 89 Isuzu Pup
Postby hessmess » Wed Jul 08, 2015 7:56 pm
Their inventory doesn't change much, what it been, 4 years? My kids are no longer in Portland so I don't go that way anymore. So now they increase the speed limit! Good to see you are still out there, you need to find an Isuzu!
hessmess
Re: 89 Isuzu Pup
Postby bradzuzu » Sun Jul 19, 2015 6:03 pm
You could try your hand in rattle can , should be able to find a place that can mix the color up for you Hess ..
Just scuff the one up and shoot it... Or option B, pick up a little spray gun for cheap and get a quart of paint and shoot it yourself , you have an aircompressor dontcha ??
Has thanked: 201 times
Have thanks: 363 times
Re: 89 Isuzu Pup
Postby hessmess » Sun Jul 19, 2015 7:45 pm
I thought about painting the whole thing John Deere green! Really I have! Or Camo. Anyway I do have a compressor and a paint gun but I would buy one of the newer kind. For right now it is running and I have to fix the light. But the plan is to just drive it for now and when I get the Trooper running I will down it and replace the tranny/transfercase and the clutch. I have all the parts for this. I am looking out for another hood and grill.Those got a little tweak in them. But I decided for now the Trooper is getting my attention.
hessmess
Re: 89 Isuzu Pup
Postby hessmess » Sat Aug 15, 2015 11:24 pm
Another quick update. It is running just fine. I replaced the rear cover on the transfer case a while back. It acted like it was bound up when you first wanted to go and then it would work. Well it seems to of worked itself out and I have put another 600-700 miles on it since then with no problems. I straightened out the bumper and hood a little and it is good for now. The A/C has been lacking for most of the summer. I had put a product called Freeze 12 in it years ago with no problems until now. Anyway I still had 1 can left and after I found a set of gauges with a side tap I dumped the remaining can and now the A/C is working fine. I could not find a leak until I noticed the shrader valve on the low side of the compressor was all greasy, I tightened it up so hopefully that will end the leak. I have been thinking about the Amigo fenders and if I can find some I think I will go ahead and replace those on the Spacer. I will get it painted after that. This little truck has been good to me so I have decided for now to keep it. The Trooper is still not running yet and that project has been stalled for over a month now. I have all the parts, just not a lot of time lately.
hessmess
Re: 89 Isuzu Pup
Postby tbecktold » Tue Dec 15, 2015 1:06 am
hessmess wrote:Their inventory doesn't change much, what it been, 4 years? My kids are no longer in Portland so I don't go that way anymore. So now they increase the speed limit! Good to see you are still out there, you need to find an Isuzu!
Speed limit is still 65 afaik? My job moved to Spokane WA though, so I followed it. I'd love another Isuzu, but we have 5 rigs and 3 are still projects...maybe someday... Glad to see you're still having fun with the old girl!
tbecktold
Re: 89 Isuzu Pup
Postby hessmess » Tue Dec 15, 2015 9:34 pm
Good to hear from you again. I still have the pickup but it is currently parked as I got the Trooper back on the road 2 months ago. It still runs and I would have no problem going somewhere it it. It just passed 195K. I started thinking I have no idea how many miles are on the timing belt and such so until I get around to doing that I will just park it for awhile.
hessmess
Re: 89 Isuzu Pup
Postby squatch » Wed Dec 16, 2015 1:05 am
Is it actually possible to have 2 Isuzu's on the road at the same time? I thought one in the garage was a requirement.
squatch
Re: 89 Isuzu Pup
Postby hessmess » Thu Dec 17, 2015 9:53 am
Squatch,
It is possible, I have photo evidence! But I admit it is rare. How about if I say 2 running but maybe not moving?
hessmess
Re: 89 Isuzu Pup
Postby wmorrisiii » Tue Dec 22, 2015 10:46 pm
I need photo evidence, LOL, not possible....just not possible.
If it was then you could work on one when you wanted to, not when you had to. That never frigging happens.
The Duck Marsh Debutante
The Coonhound
wmorrisiii
Has thanked: 86 times
Have thanks: 171 times
Re: 89 Isuzu Pup
Postby hessmess » Wed Dec 23, 2015 9:48 am
I know it is rare but yesterday I drove both of them. I was using the Trooper and then the wife wanted something moved. The Trooper had a snowblower in the back so I used the pickup to go get a small air hockey table for the kids.
hessmess
Re: 89 Isuzu Pup
Postby hessmess » Sat Apr 02, 2016 9:27 pm
Just bought some parts to show the little truck some love. I have no idea what the timing belt and stuff look like anymore and I have put about 20K on this little truck. So I ordered up the belt kit and water pump. It still runs great and I want to keep it going so this is needed. It has a little hesitation sometimes and the check engine light will flash for a second so I am going to have to look into that. I am going to look for a bad ground first and then I might look at the fuel pump. Last time it went out, I bought the cheepo to get it back running. It would not surprise me if it is going out again. It has been a couple of years of driving now.
hessmess
Re: 89 Isuzu Pup
Postby justcuz » Mon Apr 11, 2016 5:16 pm
I have a question about the Amigo front fenders.
Do they bulge out more over the tires and if so does it require bigger inner fender wells?
Glad to see the truck is still around. Got a buddy up in Yerington I visit, Nevada is a pretty cool state!
justcuz
Re: 89 Isuzu Pup
Postby -88- » Mon Apr 11, 2016 10:02 pm
To answer your questions yes & yes.....tho bigger inner fender wells is a strange way to phrase it.....it's a plastic inner fender skirt.
For this post the author -88- was thanked by:
hessmess
Has thanked: 15 times
Have thanks: 103 times
Re: 89 Isuzu Pup
Postby justcuz » Mon Apr 11, 2016 10:14 pm
Wasn't sure how they were constructed, so I phrased as a general question. You knew what I meant.
justcuz
Re: 89 Isuzu Pup
Postby hessmess » Tue Apr 12, 2016 8:55 pm
Glad 88 had the answer, as in Northeastern Nevada has no junkyard to troll through. I have thought about this but haven't spent any time looking.
hessmess
Re: 89 Isuzu Pup
Postby justcuz » Wed Apr 13, 2016 11:18 pm
I found a pair of blue fenders on an Amigo today, they would have to be stripped and repainted and the left side did not have the inner fender splash shield.
justcuz
Re: 89 Isuzu Pup
Postby hessmess » Thu Apr 14, 2016 9:14 pm
My truck is a brown color, I have a replacement fender for the rusted out one but it is blue also. Then the kids tapped a mule deer last summer and now I also need a hood and some grill parts.
hessmess
Re: 89 Isuzu Pup
Postby hessmess » Sat Apr 30, 2016 8:00 pm
Put the little truck to work today, I started cleaning up the driveway and sheds so I could put more stuff I "I need" in them. I have 2 engines I have to store for awhile. So now it has 2 automatic transmissions and a 5 speed in the back. And a 3rd member and some exhaust parts.Tomorrow I will put some more of the stuff from the 3.4 conversion on the Trooper that is taking up space in the garage. I haven't been able to put a vehicle in there for some time now. It is handling the load pretty good. Hope it has the power to pull it down the freeway on Monday.
I also put out a feeler for some Amigo fenders and hood to replace the bent ones from last summers encounter with a mule deer. Found some close, just depends on the shape they are in and how much they would half to have for them.
hessmess
Re: 89 Isuzu Pup
Postby hessmess » Sun Jun 12, 2016 8:55 pm
I just looked at the start date on this thread, 2011. I have had this little truck for 5 years now. It is still running great, but does need a little attention. I have the parts to do the timing belt and water pump, the front seal is leaking a bit worse now so that will also be replaced also. I have been spending to much time on the Trooper! I sold my F150 a month or so ago. So now this is my only pickup. I looked for an Amego front end, thought I found one but they never responded to my email. I will find one someday. I did run it this weekend and steamed cleaned the exterior and the engine. I am amazed how this little engine runs as good as the 3.4. Not as fast but still runs down the freeway at 75. I have a set of seats from a Trooper with the armrests that are in good shape I may put in. That would clear up some space in the sheds anyway.
hessmess
Re: 89 Isuzu Pup
Postby squatch » Sun Jun 12, 2016 9:24 pm
When I look back in the Black Beans thread I have had it since 2011 as well. And still trying to get it on the road for more than a day or 2!
You're doing good!
squatch
Re: 89 Isuzu Pup
Postby hessmess » Wed Aug 24, 2016 10:18 pm
Well I decided this last week the time had come to replace the timing belt on this. I sold my travel trailer I rarely used anymore, the driveway is completely cleared out. So I bought one of those pop up tents for shade and got to work. I had hoped that I would not have to pull the radiator but that suborn bolt in the dampener changed my mind. I have tried the bump trick, stalled the starter, locked down the trans/4 wheel drive and still moved the truck. I used an small impact, didn't work. Got a bigger impact, nope that didn't work either. My next step was to get a 3/4 impact gun but I really don't want to hurt the internals. Don't know if it would but I really don't want to chance it. So I have spent a better part of the afternoon researching and have read through Squatch's threads and think I will try his approach next. We are in year end at work so I may not get to it until the weekend but it is on top of my agenda. that and trying to get the AC going in the Trooper.
hessmess
cron
