1983 Yamaha Venture Royale
Postby DSUZU » Fri Mar 18, 2016 6:23 pm
Okay, so I FINALLY get around to starting the official build thread of my Yamaha Venture Royale. The background (from my Spacecab thread) On December 12th of 2015, this bike was GIVEN to me by my friend Mike. It had been given to Mike about 5 years ago by it's form owner. The bike hadn't been run since 1998, when that owner's wife had their first child and said "no more bike". On getting the bike, MY wife said "no working on the bike until you are done fixing stuff around the house (another potential build thread that included -started as- painting the inside, all main living area flooring - had to scrape every square inch of glue :cry:, and a host of side projects as we (are still going on) went. At some point I negotiated "Motorcycle therapy" which broke down into 30 minute (okay maybe two hours here and there) "sessions".
It started with cleaning "rat waste" out of the battery box, jumping the bike to make sure it wasn't seized from sitting (at many points there were "if this doesn't work, the bike goes" decisions. From there, all the hydraulics were frozen or inoperable (it has dual front calipers, and a disc rear brake as well as a hydraulic clutch - kind of an Isuzu on 2 wheels :D. Then came the "I have to hear it run or it goes" - covered that in the Spacer thread. Last week, I rigged an auxiliary gas tank (the main tank leaks, but I have a replacement), and got it started and running on it's own. Today, I finally decided the rear brakes were going to get bled. You think an Isuzu clutch is bad? The rear brake is plumbed from the reservoir (see picture) down to the master cylinder, then UP to the top of the front forks and down to the left front caliper :roll:. I figured a way to pressurize the master cylinder - using the banjo from an Isuzu front brake hose :D. Next biggie will be replacing the fuel tank (wait till you see the pictures of THAT, and replacing the clutch slave cylinder, and handle bar master cylinders. Time, patience, and waiting for the wife to go somewhere for a couple of hours. Tomorrow, front door and frame (of house) get replaced :( .
Has thanked: 220 times
Have thanks: 625 times
Re: 1983 Yamaha Venture Royale
Postby DSUZU » Fri Mar 18, 2016 6:33 pm
IIRC, I can only post 4 pics per entry, so here is the 5th. Also forgot that in the Spacecab thread, I covered the great fun of removing and cleaning the starter. I won't repost that here due to time. Here is the pic of my temporary gas tank hooked to a fuel pump that hadn't pumped fuel for 18 years. The regular gas tank is shaped like an upside down "Y" with the base of the "Y" at the top (visible in the carb picture), and the tops on each side of the rear (air ride) monoshock.
After a short bit of running, the carbs worked fairly well for having sat so long. Mike had told me he had them off and they were clean inside. They don't have chokes, but a primmer valve that adds fuel when "choked". One valve was stuck full open, and one was stuck full closed. All are freed up now.
. Dennis
EDIT: Oops! 1 electric fuel pump, 2 main tank, 3 aux tank.
Postby shaggydoink » Sat Mar 19, 2016 9:12 am
Subscribed! :thumbup:
Has thanked: 753 times
Have thanks: 386 times
Postby Von » Sat Mar 19, 2016 12:14 pm
Those are great bikes! My dad had an 86. He was pulling a trailer on The Dragons Tail and his clutch cable broke in third gear.... Adventure!
2004 Pontiac Grand Prix GTP
Von
Has thanked: 17 times
Have thanks: 34 times
Postby -88- » Sat Mar 19, 2016 1:28 pm
Well look at that i'm now more jealous of your dad that I am of you....one day I dream of riding the dragon. \m/
This is my inadvertent subscription Dennis....fuel pump eh? So it's fuel injected & not carbed? Can't read everything atm on this post to catch up, if it was mentioned?
Has thanked: 15 times
Have thanks: 103 times
Postby bradzuzu » Sat Mar 19, 2016 4:04 pm
Looking forward to your mischief on this lol
Has thanked: 214 times
Have thanks: 375 times
Postby DSUZU » Sun Mar 20, 2016 12:50 pm
Hey guys. Thanks for the replies. James: no, it is carbureted - 4 carbs to be exact. The fuel pump is because the main part of the fuel tank is below the carbs. Like our EFI Isuzus, there IS a safety feature where if the engine quits, the fuel pump quits.
Now for the REAL news: I'm in the hospital!!! I had some chest discomfort yesterday that included my left arm. I mentioned it to my daughter, who is an RN, and here I am. The good news is so far, all tests came back good. They will probably keep me until tomorrow and do a stress test. If that's okay, I go home, if it isn't, they'll schedule a procedure. FWIW, tomorrow, is my 60th birthday :roll:. I'm actually in my daughter's wing right now, but she can't be my nurse (she's working today). She DID pull a bunch of strings and got me hooked up with some of the best doctors and one of the best rooms (now if they could only get that Yamaha up here :D). Oh the bad news: no more doughnuts :cry:. Dennis
Postby -88- » Sun Mar 20, 2016 3:55 pm
Trying to make me 'spit take' my french toast and coffee? WTF is wrong with you......i'm all uh-huh interesting....carbs above the gravity cut off, interesting.......Oh look he mentioned isuzus in the motorcycle post, good man that Dennis is.......A effin heart attack what the heck!? Okay maybe just a faux heart attack, who knows maybe just weird indigestion......but STILL it was a left hook outa no where. I gotta quit associating with you old geezers.....scaring the crap out of me like this, and making me face my own mortality......tsk tsk. Hopefully this is all pretty much false alarm stuff, or maybe an early catch thing & you just start carrying an aspirin with you at all times. Maybe it can at least be a good excuse to get the wife off of you about the honey do's & you can focus on honey zu's, motorcycles, and coots.....I hate hearing this though, I really do.....I hope it does turn out to be nothing......and atleast glad to hear for now....you're doing good and in high spirits.
Postby radare » Sun Mar 20, 2016 6:07 pm
Hope the tests turn out negative and it turns out to be nothing.
If you end up needing help with those carbs? I have quite a bit of knowledge with the Yamaha XJ600 and it's downdraft Mikuni's. I've probably rebuilt and tuned more than a dozen sets to-date.
radare
Have thanks: 40 times
Postby itsmehb » Sun Mar 20, 2016 6:27 pm
Jeez Dennis, here I am reading the interesting posts as I usually do, expecting to read about your cycle and here you are in the hospital. As we age we have those days when we have a twinge somewhere and have to decide, should I go or should I ignore it. It's smart not to ignore it, and here's hoping all's well so when I visit here they'll be more cycle stories.
1991 Pick up (long gone)
2000 Amigo, 2.2 5 speed(sold)
itsmehb
Has thanked: 116 times
Have thanks: 210 times
Postby wmorrisiii » Sun Mar 20, 2016 7:04 pm
What HB said. No matter what you think, best to get checked out. Any cardiologist will tell you that their biggest issue is with under reporting prior to any cardiac event. Too many people sit around and wait for the symptoms to go away. Good you have a medical professional in the family who insisted you get checked out. In the grand scheme of all things medical I'd much rather be taking my aspirin a day and getting my yearly physical, stress testing, and ECG, than going through the indignity of another frigging colonoscopy. Hope all is well and you are out soon! It is a bitch when you still feel like you are in your 20's...but you aren't.
The Duck Marsh Debutante
The Coonhound
wmorrisiii
Has thanked: 87 times
Have thanks: 178 times
Postby DSUZU » Sun Mar 20, 2016 8:41 pm
Thanks for the kind thoughts guys. Yeah, this started a week ago, right in the middle of Sunday church service. I thought "I hate to make a scene" (our church has full security and medical staffing). After church, I felt fine and even rode my bike in the afternoon. A couple of little episodes during the week, but always went away. Saturday when my daughter was there... And here we are. We'll see what tomorrows tests show, still haven't seen the cardiologist - he was busy with actual heart attack patients today.
As for me... the party MUST go on! Being my birthday tomorrow, my best friend and his wife brought the party to us. My nurse gave permission to eat what I wanted and it was Cuban sandwiches and black beans and rice :D. Started in my room and we marched down the hall of the cardiac ward with me in the lead singing "There he was just a marching down the street..." The whole floor loved it. This happens to be my daughter's floor and at first she was a bit embarrassed, but soon realized "Dad's havin' fun, so EVERYONE'S havin fun!" Dennis
20160320_171446_resized (2).jpg[/attachment
Postby -88- » Mon Mar 21, 2016 12:24 am
I'm very glad to see you & everyone there is making the best of everything. Sucks there's not more info, but I understand your in less serious state, and it's the weekend.
Postby Von » Mon Mar 21, 2016 1:50 am
It's always a good day when you can embarrass the kids.
Also hope your test results come back as indigestion or something like that. An actual diagnosis that included the heart area would suck. Old geezers got enough problems with some damn diagnosis...
Compound fractures or arterial bleeding... that's the only way I'm going to a Dr again.. And thanks to overseas pharmacies that's the ONLY reasons I'll see a Dr!
BOOM!
Von
Postby gruff54 » Mon Mar 21, 2016 5:56 am
Dennis, hope it turns out well and your back to your normal schedule soon!
Mike
'88 Trooper 2.6L 5 spd
'89 Trooper 2.6L 5 spd
gruff54
Has thanked: 33 times
Have thanks: 56 times
Postby DSUZU » Mon Mar 21, 2016 9:31 am
Again, Thanks for the kind thoughts. Getting a stress test sometime today. Personally, I think the Doc should prescribe a week of Yamaha and Isuzu therapy. Dennis
Postby N law » Mon Mar 21, 2016 5:15 pm
Holy Cow! Get well soon!
My wife works on a telemetry floor and she is always bending hers or my symptoms into a major cardiac event. My family has history, so there is reason for concern, but I always have to ask myself if it is muscular/skeletal before I open my trap and get her stirred up.
My first bike was an 83 Yamaha! I had the Virago 500 (one year only in the US). It was a fun bike, but I tired of it relatively quickly with the mediocre starting system in the viragos. I ended up getting another bike about a year later. Can't wait to read more about this one!
99 VX
96 Rodeo Build thread
1975 FJ40
69 Beetle
84 Westfalia
70 VW bus turned camper
86 VW Diesel Golf
07 Frontier V6 6 speed
1999 4Runner Limitee- wife's
2004 Genuine Stella Scooter
N law
Have thanks: 63 times
Postby bradzuzu » Mon Mar 21, 2016 8:41 pm
Happy birthday Dennis !! I'm so sorry to hear you're spending it at a hospital but by the looks of things you're making a good show of it !!
I hope everything checks out and you get to go home buddy .. I'll say a couple prayers for you anyway , just because :)
Nice hat !! The outfit could use a little work though ...
Postby DSUZU » Tue Mar 22, 2016 5:59 am
Well, like the Eveready bunny, Still going! Stress test came out fine, so they released me and I went home. I am headed off to work today, and will update more after I get home. Dennis
Postby gruff54 » Tue Mar 22, 2016 6:15 am
Good news!
gruff54
Postby wmorrisiii » Tue Mar 22, 2016 8:47 am
That is good news!
The Coonhound
wmorrisiii
Postby bradzuzu » Wed Mar 23, 2016 12:57 am
Great news man !! Did you have a memorable birthday :) guess it'll be a good story to tell on down the road anyway ..
Hope that's the end of it ...
Postby -88- » Wed Mar 23, 2016 10:10 am
I echo everyone else's sediments this is awesome news......Means you're fit enough to get down to the lawyer & get that will updated. I Dennis in sound mind & (mostly) body here by bequeath my 4wd Isuzu Spacecab pickup truck to my greatest friend -88-.
Something along those lines should do it. :D
All jokes aside I really am glad to hear you're alright & it was basically false alarms. My wife can bare witness....I was down in the dumps sunday, or was it Saturday when the news broke........I wasn't Eeyore or anything, just a little off I think is how she put it. Thankfully she understands this ain't just Internet car guys, but alot of real & true friends. :D Seriously glad you're okay, don't do that chit to us no more.
For this post the author -88- was thanked by:
Postby DSUZU » Wed Mar 23, 2016 4:31 pm
Heck James, forget the will (of which we have a really good one), you need to contact my WIFE. She'd probably have you haul ALL of my crap off :D. If you'd caught her Sunday morning, it might all be yours now. On a more serious note, in the event of my passing, I have my kid brother and my best friend who would step in and take care of anything my wife needs (not to mention my church). My kid brother regularly runs estate sales and if he doesn't already know what something is worth, it don't take him long to find out. This was a sobering thought. About 18 months ago, my bro did a sale for a deceased mechanic / car guy. Huge 30 x 40 garage shop full of stuff, but scrambled everywhere. Welder "Dirty Dan" (like me) from work and I were given a preview (and pre purchase) showing. As we were going through the stuff I said "Man, this could easily be your garage or mine". I'm thinking about tagging all the various parts boxes to the Yamaha, Coot, and Spacecab, just so everything could easily be rounded up. P.S. thanks for the concern. you guys are more than just posts on an internet forum. Man how I wish it were possible for there to be a gathering of folks here.
On a different note: A vendor brought TWO boxes of doughnuts to work today. I didn't eat nary a one :D. Tempting, but you have to start somewhere. Dennis
OH, one more thing. Yammer has a small coolant leak. Apparently the O-ring around the plastic thermostat housing. Probably nothing will happen over the next week as I have spring break company coming down, but then again....
Postby shaggydoink » Sat Mar 26, 2016 8:23 am
I was travelling most of the week for work and just able to catch up here on the Planet this morning... a belated HAPPY BIRTHDAY Dennis, and I'm so glad to hear that you're doing OK, my heart sank when I read that you were in the hospital. :( Take good care of yourself!!
Return to Other Vehicles
