How bad of an idea is this?
Use this forum to post about something that doesn't fit in any other topic (ex: link to the picture of the Toyota in a sink-hole)
Re: How bad of an idea is this?
Postby Hack » Wed Jan 18, 2017 10:26 pm
I wouldn't have a problem doing it with my BFG KA2s but I think that you'd go nuts with MTs like Swampers. The noise alone would drive you crazy unless you had a well insulated truck with a loud stereo. As for the ride, you are much younger than me so maybe your body won't mind. Finally, I can't image that you'd get very good mileage with those tires. There is a reason that people buy ATs.
In the old days, I seem to recall you trailering the trail tires.
Mario
Hack
Has thanked: 7 times
Have thanks: 128 times
Postby paulevans76 » Thu Jan 19, 2017 2:34 pm
It all depends, but I wouldn't let a little tire hum stop me from a good time.
Has thanked: 75 times
Have thanks: 81 times
Postby Carl747 » Thu Jan 19, 2017 3:17 pm
Everybody would hear you coming up behind them and know that it is you. Plus you would look a good bit cooler than everyone else.
As long as the wear on the tires doesn't bother you, I would do it.
98 Trooper S. 230k miles, Dark Blue.
Carl747
Has thanked: 4 times
Postby wmorrisiii » Fri Jan 20, 2017 12:29 am
Why not? I think it's a great idea, but it might shake a few things loose during a run like that...just adds to the experience though.
The Duck Marsh Debutante
The Coonhound
wmorrisiii
Has thanked: 86 times
Have thanks: 171 times
Postby squatch » Thu Jan 26, 2017 3:55 pm
Should make shortcuts easier! :lol:
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 66 times
Have thanks: 326 times
Return to General Chit Chat
Users browsing this forum: ddomino and 2 guests
