The heavy part of my job ....
Use this forum to post about something that doesn't fit in any other topic (ex: link to the picture of the Toyota in a sink-hole)
Postby bradzuzu » Thu Apr 12, 2012 4:27 pm
Some of you know I'm a heavy construction mechanic... Well this is one of those days where you pucker !!
That's a 10' tube on that there wrench, the hydraulic cylinders have a huge gland nut put on to about 6-800 ftlbs of torque !!! In the past I have used a mini excavator to push on the wrench just to break that torque... One down and one more to go.. I think each cylinder rod weighs 150 plus lbs to uuuggg !!!
Has thanked: 188 times
Have thanks: 354 times
Re: The heavy part of my job ....
Postby BigSwede » Thu Apr 12, 2012 4:35 pm
Archimedes would be proud...
BigSwede
Has thanked: 14 times
Have thanks: 244 times
Postby bradzuzu » Thu Apr 12, 2012 5:09 pm
Lol thanks Swede..!! So funny the rest is relatively easy it's just that big ole nut.... And unfortunately the crowd cylinder is leaking out its gland to , and it's even bigger !!
Postby The Dude » Sun Apr 15, 2012 9:01 pm
THAT is just NUTS! lol
R.I.P. "89 Trooper 2.6l 5-speed, Indy4x add-a-leaf w/ shackles, T-bar crank, BJ flip w/ spacers, lsd, rear wheel well razor blades, invisible front susp. limit straps, custom cigarette burn on center console"
yes im going poo right now
The Dude
Has thanked: 19 times
Have thanks: 14 times
Postby bradzuzu » Sun Apr 15, 2012 9:09 pm
Oh ya !! And it about broke mine lol
Postby The Dude » Sun Apr 15, 2012 9:13 pm
6-800 ft lbs, 10' bar.. jeesh, I believe it. thats just insane!
The Dude
Postby Ruination » Sun Apr 15, 2012 9:14 pm
Oh, the things you have to do to Bust a nut sometimes... :lol:
1992 Isuzu Pickup w/some mods
1999 Mitsubishi Montero fully loaded
2008 Saturn Sky Redline
Ruination
Have thanks: 56 times
Postby The Dude » Sun Apr 15, 2012 9:24 pm
Ruination wrote:Oh, the things you have to do to Bust a nut sometimes... :lol:
:lol: :lol: :lol: :lol: :lol: :lol: :lol: TOO FUNNY!!
The Dude
Postby The Dude » Sun Apr 15, 2012 9:28 pm
sometimes a lil lube will do it
The Dude
Postby Tad » Sun Apr 15, 2012 9:35 pm
What exactly is a IHCATIH? You're going to need a wrench that has enough curve to match the earth to loosen a larger nut. Time for one of those 3/4" drive impact wrenches.
-Tad
Tad
Site Admin
Has thanked: 119 times
Have thanks: 93 times
Postby Selahdoor » Sun Apr 15, 2012 9:44 pm
Tad wrote:What exactly is a IHCATIH? You're going to need a wrench that has enough curve to match the earth to loosen a larger nut. Time for one of those 3/4" drive impact wrenches.
-Tad
HITACHI
-Jeff
1988 Trooper LS. 4ZE1. mua5.
Selahdoor
Forum Admin
Has thanked: 94 times
Have thanks: 165 times
Postby Selahdoor » Sun Apr 15, 2012 10:18 pm
Tad wrote:That's like a Folex watch, right?
And a Soany stereo system...
-Jeff
Selahdoor
Forum Admin
Postby bradzuzu » Sun Apr 15, 2012 10:24 pm
Don't ask me who put the sticker on backwards lol.... I think gremlins !! I've got a great big 3/4" impact gun that will pop semi truck lugs but this sucker just laughed at it..
Postby COYOTE102076 » Mon Apr 16, 2012 6:56 pm
Who do you guys use for seal kits? I would immagine the OEM HITACHI seal kits are wicked expensive.
We have for years used BAUM HYDRAULICS for hyd. seals. HUGE selection and an awesome low price.
Just a thought.
http://www.baumhydraulics.com/home.php? ... 13a43d3fff
Give 'Em a call and they will gladly send you the "Big Red Book" of seals.
Absolutly invaluable to have on hand.
Where I work, the problem became that may of the (MUCH SMALLER) hyd. cylinders we got in for repair had seal kits that were no longer avalable from the OEM supplyer. So I had to come up with SOME kind of way to rebuild them. (O-Rings & backup rings dont allways work / fit every cylinder. I needed SEALS for some goofy made cylinders)
COST was another big factor. Here in "Poor Farmer'ville" TN, these old guys running 6265 Deutz Allis tracotors were having heart falure over the factory power steering cylinder seal kit costing $159.00
I was able to order each individual seal & metric o-ring needed from BAUM for a fraction of the cost and can sell my own seal kit for them now for about $45.oo RETAIL! :wink:
-==Kevin J.
1994 Trooper "The Phoenix": given to my 16 year old son
My Rides: 1) 2005 Volvo XC90 Turbo 2) 2004 Mercedes Benz S500 3) 1988 Jeep Comanche Pickup
COYOTE102076
Has thanked: 75 times
Have thanks: 35 times
Postby bradzuzu » Mon Apr 16, 2012 8:01 pm
Wow that's not bad at all !! The dealer wants proble $350-$450 per kit (rediculous) I have a wear house called seal source that I have a company get mine at for $120 each roughly.. It's crazy how a dealer will charge/markup prices on these simple kits...!! It's all hate and discontempt , when ever you talk about dealers, car, truck or machine... Now Jerry on the other hand is awesome and treats us right !!!
Ps us mechanics are professionals in bustin NUT's dontcha know :)
Postby trooper T/diesel » Wed Apr 18, 2012 5:39 pm
you need one of these really BAD BOYS
light duty 3,500 ft lb 1 1/2" drive, eats up 44CFM, on a 1/2" air line
when the tank runs out of air your glad it did because your arms feal like hamburger.
there right down the road from me....
http://www.vannattabros.com/shop.html
trooper T/diesel
Have thanks: 21 times
Postby bradzuzu » Wed Apr 18, 2012 6:12 pm
I've got an older version of that for the truck lugs, in reality I think these nuts where on with a torque of 900-1200 ftlbs... It's always harder to break loose a torqued nut compared to retorqueing ... I had my body weight (175) on that bar and had to bounce to break it loose !!! I was more afraid of eating my teeth into the concrete !!
Postby bradzuzu » Wed May 30, 2012 5:37 pm
I'm having another one of those days haha !! Just pulled the pan on this dump truck for an inspection of fine metal... The cam has a bad spot !!! So the whole top end and front end has to get pulled to replace it... Good times !!
Postby The Dude » Wed May 30, 2012 6:06 pm
GOOD GOD!!! that thing is huge! :shock: I know how big motors can get but man, I've never actually seen the parts or anything to compare em with
The Dude
Postby bradzuzu » Wed May 30, 2012 6:39 pm
I know they are fricken animals !! I've done two inframes in This sucker in the 20 years Ive been at this company... Poor girl gets worked hard... I'll post more pic's as I tear into it..
Postby COYOTE102076 » Wed May 30, 2012 8:42 pm
INTERESTING!
What engine is that? Displacement?
I would like to know (rough guess, dont have to be exact) what the camshaft in that BEAST weighs!!! :lol:
My guess is a 12.7L Detroit Diesel. But that is just a "shoot from the hip" guess.
-==Kevin J.
COYOTE102076
Postby bradzuzu » Thu May 31, 2012 12:00 am
Close !! It's a big cam 350 cummins... I will be pulling that massive camshaft out to replace it along with the rocker assembly's... I really thought it had a burnt piston , still a big job... Hoods off and rad is ready to be lifted off..
Postby johnny5ive » Thu May 31, 2012 1:17 am
I suddenly feel like a big pussy... Thanks a lot Brad!!
johnny5ive
Postby bradzuzu » Thu May 31, 2012 11:28 am
Lol We all work hard at what we do John... But that's fricken hilarious 8) !! Your bust your balls all the time ,hell you bust my balls...!!
Return to General Chit Chat
