VOTG: U-Joints
Use this forum to post about something that doesn't fit in any other topic (ex: link to the picture of the Toyota in a sink-hole)
Re: VOTG: U-Joints
Postby DSUZU » Fri Mar 31, 2017 5:49 pm
Excellent. This will become the standard answer for folks with driveshaft issues. Dennis
Has thanked: 220 times
Have thanks: 624 times
Re: VOTG: U-Joints
Postby lorenzo816 » Wed Apr 19, 2017 9:22 am
this video is what my fabricator uses to show people how driveshafts should work.
Its unreal how many people think that you need to turn your pinion up and then run a shaft without a double cardan at the out put side.
its also kinda mindblowing how the little credit card tooth tapping sound speeds up and slows down when the driveshaft angles are changed.
kinda mindblowing and really illustrates how the trans and pinion need to be aligned.
lorenzo816
Has thanked: 84 times
Have thanks: 64 times
Return to General Chit Chat
