CV Replacement
Use this forum to test posting messages and pictures before posting on the actual forum. If you are a new user, this is a great place to learn how to post
CV Replacement
Postby iTunes » Tue Jun 07, 2016 9:54 am
Hey guys does it look like I need CV replacement?
iTunes
Re: CV Replacement
Postby Hack » Tue Jun 07, 2016 10:55 am
It depends on how long the boot was cracked, how much grease leaked out and ultimately how much damage there is to the bearings. If the bearings are good, you can clean out the old grease, and replace the boots and grease. If the bearings are shot, replace the CV.
Mario
Hack
Has thanked: 7 times
Have thanks: 130 times
Return to Test Forum
