brakes
Use this forum to test posting messages and pictures before posting on the actual forum. If you are a new user, this is a great place to learn how to post
brakes
Postby gbslatj6 » Thu Jan 21, 2016 11:08 pm
replaced driver side caliper. when i bleed it i get just an ooze of fluid and some air. bled it several times with same result. no brake pedal pressure builds up
gbslatj6
Re: brakes
Postby Apeiron » Fri Jan 22, 2016 10:55 am
Keep bleeding.
Leave the bleeder screw open while topping up the m/c reservoir as necessary until fluid starts to come out under gravity, then bleed as normal.
1993 Amigo 4wd Hard top, Delta 260, elephant feet, Skyjacker Nitros, 3" suspension lift, Indy4x HD tie rods, Revolution Gears, Maxxis MT-764s 31x10.5x15
Apeiron
Have thanks: 54 times
Re: brakes
Postby gbslatj6 » Sun Jan 24, 2016 1:49 pm
gravity bled brakes, fluid and air came out. air never stopped coming out of the caliper and when i push the brake pedal down air bubble are coming in to the master cylinder reservoir. is the master cylinder bad? i have only fluid coming out of the rear and lots of air coming out of the front.
gbslatj6
Re: brakes
Postby JoeIsuzu » Sun Jan 24, 2016 4:17 pm
I'd repost in the right section of the site. Lots of posts in this section just get ignored.
Jack
Original owner, 1983 Isuzu P'up LS Diesel. Engine overhauled by JLEMOND. Ready for new paint now!
1994 Isuzu Amigo 2wd
IsuzuPup.com
"There are no dumb questions"?! Maybe not...
but there are smart ways to ask. Old, but classic:
How To Ask Questions The Smart Way
JoeIsuzu
Has thanked: 73 times
Have thanks: 76 times
Return to Test Forum
