Power Steering Fluid Confusion - 94 Trooper
Postby Kilroy2032 » Wed Jan 11, 2017 6:11 pm
Hi all,
Been a while since I've posted, hope the holidays were good to everyone.
I've read that dark/black power steering fluid is pretty bad and should be flushed out right away. With my trooper, the cap reads "Power Steering Fluid Only" but the manual and any other spec site I find says Dexron IIE ATF. So yeah...which one?
I've tried searching forums here but maybe I'm not doing it right?
Thanks,
Thom
Kilroy2032
Has thanked: 36 times
Re: Power Steering Fluid Confusion - 94 Trooper
Postby BigSwede » Wed Jan 11, 2017 7:15 pm
Either works. I would use PS fluid so you can tell what is leaking by the color.
95 Trooper LS - 4" lift, 35" tires, 5.38 gears, ARB lockers
Indy4x Revolution 3.07:1 low range gears, Indy4x HD tie rods, homemade sway bar disconnects, Calmini HD sway bars, Darlington diff drop, OME 929 coil springs + 1" poly spacers and 1" body lift, Indy4x HD torsion bars, Indy4x HD rear axle links, Indy4x Kevlar brake lines, ARB bullbar, custom rear bumper with swing-out dual jerry can carrier, rock sliders, Sears Platinum Group 31 battery, ARB mini-compressor, Indy4x kevlar air lines, Warn M8000 winch, Blue Sea 6006 winch cutoff switch, Yaesu FT-1900R 2-meter ham radio, Larsen MHW-150C 1/2 wave antenna, Cobra 18WXST CB radio, Firestik II CB antenna, IPF driving lights, generic fog lights, two (2) Blue Sea auxiliary fuse panels, sleeping platform, and outofrshell Dave's custom 1" shifter extension. (I actually typed this list as a joke but people seem to like it.)
For this post the author BigSwede was thanked by:
Kilroy2032
BigSwede
Has thanked: 14 times
Have thanks: 249 times
Postby Med!c » Wed Jan 11, 2017 8:28 pm
They are both hydraulic fluids so either will work. I on the other hand prefer ATF because it has cleaning agents. Might not be a good idea if the PS system has been neglected.
00' Trooper 4x4- V6 3.5L
5-Speed Manual Aisin AR-5
Isuzu 12-Bolt Modified LSD
Isuzu 10-Bolt Aussie Locked
BGF AT T/A KO 285/75/16
Miss my old rodeo.
98-02 Isuzu Workshop Manual: Link
For this post the author Med!c was thanked by:
Kilroy2032
Med!c
Have thanks: 86 times
Users browsing this forum: Bing [Bot] and 6 guests
