Power Steering Fluid Confusion - 94 Trooper
Postby Kilroy2032 » Wed Jan 11, 2017 6:11 pm
Hi all,
Been a while since I've posted, hope the holidays were good to everyone.
I've read that dark/black power steering fluid is pretty bad and should be flushed out right away. With my trooper, the cap reads "Power Steering Fluid Only" but the manual and any other spec site I find says Dexron IIE ATF. So yeah...which one?
I've tried searching forums here but maybe I'm not doing it right?
Thanks,
Thom
Kilroy2032
Has thanked: 38 times
Re: Power Steering Fluid Confusion - 94 Trooper
Postby BigSwede » Wed Jan 11, 2017 7:15 pm
Either works. I would use PS fluid so you can tell what is leaking by the color.
For this post the author BigSwede was thanked by:
Kilroy2032
BigSwede
Has thanked: 14 times
Have thanks: 251 times
Postby Med!c » Wed Jan 11, 2017 8:28 pm
They are both hydraulic fluids so either will work. I on the other hand prefer ATF because it has cleaning agents. Might not be a good idea if the PS system has been neglected.
00' Trooper 4x4- V6 3.5L
5-Speed Manual Aisin AR-5
Isuzu 12-Bolt Modified LSD
Isuzu 10-Bolt Aussie Locked
BGF AT T/A KO 285/75/16
Miss my old rodeo.
For this post the author Med!c was thanked by:
Kilroy2032
Med!c
Have thanks: 86 times
Users browsing this forum: itsmehb, Yahoo [Bot] and 6 guests
