Trooper Sway Bars
Trooper Sway Bars
Postby flydex28 » Sun Jan 08, 2017 12:20 am
Im looking to replace my sway bars with something a little stiffer to help with body roll. Are there any other companys out there that sell better swaybars. I know there was Calmini, but I cant seen to find any. Plus Ive read ordering from them can be difficult.
-Chris-
2001 Isuzu Trooper LS, 4X4, 3.5L, AR-5 w/TOD swap, OME 919
Transmission swap thread: viewtopic.php?f=22&t=87739
flydex28
Trail Rider
Has thanked: 8 times
Have thanks: 12 times
Re: Trooper Sway Bars
Postby 96TrooperSE » Sun Jan 08, 2017 12:34 am
Have you tried replacing your stock sway bar bushings with some polyurethane ones? I've heard a night and day difference just doing that. A nice set of gas charged shocks should help too. If you're looking for even more stiffness the Vehicross came with a thicker anti sway bar. I'd imagine it would be possible to retrofit that on the trooper since the VX is pretty much a short wheelbase trooper chassis.
I'd steer away from calmini unless you call and confirm they have what you want in stock. I just received some torsion bars from them a couple weeks ago that I ordered in July! They said 4-5 weeks when i ordered them.
2000 Trooper Limited: Was 2wd, auto, gas. Now 4wd, 5 speed, diesel.
2001 Trooper S: Castrated and sold.
1996 Trooper SE: Former beaten and battered trail cruiser. Gone but not forgotten
96TrooperSE
Has thanked: 4 times
Have thanks: 14 times
Postby flydex28 » Sun Jan 08, 2017 1:07 am
I replaced the old worn out shocks with some new kyb gas adjusts a couple years ago and didnt notice any difference. I then ordered and installed the polyurethane bushings from indy, and yeah It helped a tiny bit but nowhere near what i had read. I do hear the swaybars are a huge inprovement though. The problem is finding some. I dont even see them on Calminis site. Very interesting about the VX... I had read something about that but never read a confirmation if they would work.
-Chris-
flydex28
Trail Rider
Postby totten » Sun Jan 08, 2017 11:01 am
Maybe a stiffer spring in rear to help, and tighten up the end links on front a little,adjust the torsion bars up 1" in front. It will help the roll. I have the Calmini rear springs and torsion bars up 3" with swaybars removed. Body roll is good even with 2" body lift. Try it. I think Calmini has the springs in kit for Trooper. Good luck,Tony
2004 rodeo 4x4,3.2,auto Calmini 3" lift, Zone 2" Body Lift, 265/75/16 Bridgestone Revos. Cobra 29LTD CB,Transmission cooler,Functional hood scoop,Skyjacker shocks 8000,Swaybars removed.
totten
Have thanks: 70 times
Postby flydex28 » Sun Jan 08, 2017 2:21 pm
Well i'm trying to improve on road handling. I have OME 919 springs and torsion bars are cranked an inch already.
-Chris-
flydex28
Trail Rider
Postby 96TrooperSE » Sun Jan 08, 2017 4:16 pm
Found this old thread...viewtopic.php?t=44304. According to Smiley the VX bar is a direct bolt on. You'd just need the bigger bushings/mounts to match. I haven't read any first hand accounts of the improvements, but I read on the VX forum that the VX bar is actually a little thicker than the Calmini. I say try it out and let us know the difference!
96TrooperSE
Postby flydex28 » Mon Jan 09, 2017 2:24 am
Cool thanks, I'll have to check it out.
-Chris-
flydex28
Trail Rider
Postby ducktrooper1 » Mon Jan 09, 2017 12:32 pm
let us know what you find out as I'm thinking of doing the same.....trying to modify for better road manners since most of my driving is OTR
99 Trooper S, 4.77s, ARBs, ARB bullbar, M8000 w/Amsteel, OME 4" lift, IFS Lights, Rancho 9000xs, Aisins, BFG KO2s 285/75/16, custom sliders, K&N/Magnaflow custom, Indy 4x SS lines, Indy 4x disconnects, DOR diff drop, Hayden cooler.
ducktrooper1
Postby flydex28 » Mon Jan 09, 2017 7:06 pm
ducktrooper1 wrote:let us know what you find out as I'm thinking of doing the same.....trying to modify for better road manners since most of my driving is OTR
Will do. I need to find out if both the front and rear VX bars are thicker than the Trooper, or if I only need to swap one of them out.
-Chris-
flydex28
Trail Rider
Postby 96TrooperSE » Mon Jan 09, 2017 10:43 pm
Pretty sure it's just the front that is thicker. The rears are the same.
96TrooperSE
Postby flydex28 » Tue Jan 10, 2017 5:48 am
I think you are right. I just read on a Vehicross forum that the VX fronts are 28mm and the rear is 19mm...the bushings anyway. It also said the front is about 10% thicker but the rear is the same. I will try to remember to measure mine tomorrow to confirm.
-Chris-
flydex28
Trail Rider
Postby nasty610 » Tue Jan 10, 2017 2:01 pm
Front Trooper bar is 26mm.
1996 Isuzu Trooper Base model
1991 Trooper Base Model
Lift Coil Spring Options
nasty610
Has thanked: 21 times
Have thanks: 198 times
Postby trooper4kids » Tue Jan 10, 2017 3:30 pm
Out of curiosity, does anyone know if the Axiom sway bars fit a Trooper? If so, are they larger?
1995 Trooper - first Troop long time ago, sold when 3rd child arrived
1994 Trooper - SOHC, 5 Spd, oldest child's first car
1993 Trooper RS -my DD, DOHC, 5 Spd, bought after driving first kid's rig, realized how much I used to like first Troop!
1998 Trooper - 3.5L oil burner, 5 Spd, 2nd child's car
1999 Trooper - 3.5L needs attention, 5 Spd, 15 YO son's future driver
1993 Trooper RS - DOHC, 5 Spd/blown clutch, significant body damage, not sure whether to modify or strip and crush
trooper4kids
Mi Amigo
Have thanks: 11 times
Postby flydex28 » Wed Jan 11, 2017 2:32 am
Thats a good question, I would like to know as well.
-Chris-
flydex28
Trail Rider
Postby flydex28 » Wed Jan 11, 2017 5:37 am
Well I found this site that lets you compare vehicles. I compared the Axiom, Trooper, and Vehicross. Not sure how accurate all the info is though.
http://www.thecarconnection.com/car-com ... cross_2001
It has the Axiom at 1.0 in.(25.5mm), the Trooper at 1.02 in. (26mm), and the Vehicross at 1.10 in. (28mm).
-Chris-
flydex28
Trail Rider
Postby totten » Wed Jan 11, 2017 11:39 pm
Axiom sway bars should be same as Rodeo,don't know if they would fit Trooper.
totten
Postby trooper4kids » Thu Jan 12, 2017 9:56 am
I always assumed the Axiom was based on the Trooper platform. Is it Rodeo based?
trooper4kids
Mi Amigo
Postby squatch » Sat Jan 14, 2017 12:24 pm
The stock Trooper bars are hollow. The Calmini bars are solid and much bigger. They make a huge difference. If you can't find these try ADDCO or Helwig.
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 65 times
Have thanks: 316 times
Postby flydex28 » Sun Jan 15, 2017 7:50 pm
squatch wrote:The stock Trooper bars are hollow. The Calmini bars are solid and much bigger. They make a huge difference. If you can't find these try ADDCO or Helwig.
I looked up ADDCO and they dont sell them for the Trooper after 91 I think it said, Helwig I didnt see a vehicle list.
I read that it really doesnt matter if the bar is solid or hollow for some reason
I will keep searching for the Calmini bars but I think the VX bars may be the best bet if they fit.
-Chris-
flydex28
Trail Rider
Postby rbral » Sun Jan 15, 2017 8:05 pm
Part of a kit. I bet they would sell it separately
https://www.calmini.com/detail.php?b=3& ... 1&p=920&n=
rbral
Postby flydex28 » Sun Jan 15, 2017 10:55 pm
I saw that, but it doesn't come with the front sway bar. I suppose I could give them a ring and ask. Wonder how much they cost.
-Chris-
flydex28
Trail Rider
Postby ducktrooper1 » Mon Jan 16, 2017 11:19 am
Let us know what you find...I'd definitely be interested in some if price is reasonable.
ducktrooper1
Users browsing this forum: MarkB.NV, Yahoo [Bot] and 8 guests
