OBDII Fuse?
OBDII Fuse?
Postby ZuminaZX » Sun Oct 05, 2014 4:35 pm
I have power at my OBDII port in my 04 Rodeo but no connectivity to the ECU. Is there a fuse in line between the port and the plug somewhere? I've examined all the fuses under the hood and in the fuse compartment and they're all good.
2004 Rodeo 3.5 DI
ZuminaZX
Have thanks: 22 times
Re: OBDII Fuse?
Postby totten » Sun Oct 05, 2014 4:42 pm
I have no idea. Maybe Buster28 will chime in to help you.
totten
Have thanks: 83 times
Re: OBDII Fuse?
Postby Buster28 » Mon Oct 06, 2014 10:34 am
+12 Vdc to the DLC is on Pin 16. On my 01 & 02 Rodeos and on 04 Axiom the power to pin 16 is supplied by a 10 Amp fuse labeled "Horn" I expect a 04 Rodeo would be the same.
02 Rodeo Sport 4X4 3.2L V6
01 Rodeo Sport 4X4 3.2L V6
Buster28
4L30E Guru
Have thanks: 874 times
Re: OBDII Fuse?
Postby wraider1 » Wed May 10, 2017 11:05 am
Thanks, 10A Horn fuse blown, not sure what caused it, but can get inspected now. :)
wraider1
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 6 guests
