Late Model Isuzu FAQ
Postby Tad » Fri Mar 04, 2011 11:00 am
It's not my fault, but I took on the task of hosting it and have been slacking (I did get busy). It should be back up tonight.
-Tad
Tad
Site Admin
Has thanked: 121 times
Have thanks: 93 times
Postby starhi » Fri Apr 29, 2011 5:13 am
thanks for the info
starhi
Postby twilson » Tue May 31, 2011 3:15 pm
:oops: :salute:
great site!!
-Tyler
02 Trooper Debagged, 5 Speed ,170k, New Engine/Clutch, Pressure Plate,
Throw Out Berring @ 77k & again at 147k - Rebuilt trans around 90k - LS wheels, Running Boards, CB Radio
MagnaFlow Catback Exaust, Piaa H3 Hid Fog lights, 20% Front 5% Rear Tint, Black Gloss Painted LS Wheels, Glow Shift Volt Meter Pillar Gauge, Tinted Tail Lights, Alpine / Kenwood / Pioneer / Full Sound System, 1 12'' Kenwood sub, RAM Grille Guard , New Shocks / Tires
PICTURES
MY RIDE
twilson
Has thanked: 30 times
Have thanks: 9 times
Re: Late Model Isuzu FAQ
Postby wdog118 » Wed Nov 02, 2011 12:13 pm
saw this this other day, GREAT source of info. Thanks for posting it!
1996 Rodeo S 3.2 V6 5spd.
Treadwright Guard Dogs 265/70R16 :-D
Converted HVAC controls from 2nd Gen.
2" Calmini lift.
Indy4x bushings.
Click on the pictures for more pictures.
wdog118
Trail Rider
Postby Leadtrombone » Wed Sep 17, 2014 12:02 am
Is this FAQ site down permanently?? I can't seem to reach at any of the links in the thread.
Leadtrombone
Postby octopus » Sun Sep 21, 2014 11:30 am
I never really contribute around here but have gotten lots of good info to help with my pickup, so when I couldn't get back to sleep last night, I took a shot at making a wiki page on Wikia.com and took a shot at rebuilding the FAQ. I found a version of it by using the Wayback Machine web archiver and copied out of that.
The site still actually exists at http://www.walkerdowney.com/ryanendres//isuzu/#faq6 , but I figure with personal sites it's only a matter of time before it would vanish again. So I made the wiki page, did as much reformatting as I had energy for and completed the index. Now if I understand it right, any of us can go in and edit to improve it. All the links that should go down to the answers or back to this site go to the web archive, I replaced a few here and there so if anyone is feeling like fixing that, go for it. Once you're in Edit Mode it's pretty easy. You can add pictures too. I'm just figuring this out, you'll probably catch onto quicker and do more with it.
Here it is, hope it's useful once again!
-Jeff P
http://isuzu.wikia.com/wiki/Isuzu_Wiki
octopus was thanked by:
JD4010TacoSupremez
octopus
Postby JD4010 » Mon Nov 10, 2014 3:40 pm
octopus wrote:I never really contribute around here but have gotten lots of good info to help with my pickup, so when I couldn't get back to sleep last night, I took a shot at making a wiki page on Wikia.com and took a shot at rebuilding the FAQ. I found a version of it by using the Wayback Machine web archiver and copied out of that.
-Jeff P
Thanks for that!
--1997 Rodeo S 4WD; 3.2L V6 & 5-speed stick
JD4010
Postby TacoSupremez » Sat Nov 15, 2014 12:13 am
This will come in handy.
1996 Trooper SE / Fully Loaded
For this post the author TacoSupremez was thanked by:
JD4010
TacoSupremez
Postby wbuz5707 » Sun Mar 15, 2015 5:05 pm
what is this all about? I see nobody posted anything new on this thread. I keep checking and no news
wbuz5707
Postby Amigo-2k » Mon Mar 16, 2015 9:53 pm
Amigo-2k
Forum Admin
Postby CalG » Wed May 06, 2015 10:56 pm
This thread appears to be a total time waster. The links are either dead or lead to some very "fluffy" (Edmunds?) Q&A I think it should be removed!
CalG
Has a Trail Truck
Have thanks: 20 times
Postby bahmed » Sat Sep 05, 2015 3:28 pm
1998 Isuzu Rodeo V6, 2WD, Auto Maintanence FAQs
1) I was getting CEL P0134 intermittently and only when the A/C is running and the vehicle is stationary. The CEL goes away typically after driving 18 miles, sometimes after driving 4-5 miles. After taking look at the passenger side firewall under the Engine compartment, I saw the Evaporator drain hose dripping condensation (water) on the exhaust manifold and splashing some water to Band 1, Sensor 1 Oxygen Sensor (O2 Sensor). After adding an extension to the drain hose with a flexible rubber hose, the problem disappeared.
P0134 - 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
2) Hard starting on a cold start or after vehicle had been parked for few hours. The Fuel pump check valve has gone bad the fuel is draining back to the fuel tank and hence it takes sometime for the fuel pressure to develop, which is causing the extended cranking to start. Added a BMW part ($18) after the fuel filter and it has been 6 years (60K miles) didnt have the issue at all. Below is the information on how and what to order.
fuel line check valve for a BMW 1990 735 iL
http://www.bmaparts.com BMA Parts 1-888-262-3911
part number 16 14 9 068 988
about $18.00 shipped
3) Remove ABS Fuse/Relay in Fuse box inside the Engine Compartment before bleeding brakes, otherwise ABS control module will surely get damaage
4) St Charles Isuzu is no longer selling Isuzu parts, use http://www.hondaautomotiveparts.com (Select Passport) and order parts, http://www.rockauto.com is a very site for parts as well
5) Engine surging on cold start in winter or on extreme temperature changes, change Idle Air Control Valve (IAC)
6) If you know the Isuzu part#, search ebay, I could find genuine Isuzu Alternator for $100, ABS Control Module for $80, much better price than after market, plus it is a genuine part.
bahmed
Postby bcolins » Sun Jan 24, 2016 10:28 pm
Site with FAQS appears to no longer be UP. Perhaps this thread should be deleted?
bcolins
Postby gramos1046 » Sun Jun 26, 2016 10:15 pm
Hi, I have a truck isuzu rodeo 1999 v6 3200cc. free wheels need new, anyone know where to buy them, are automatic.
gramos1046
Postby wndrwmn069 » Sun Nov 20, 2016 11:38 am
I have a 2001 Rodeo 3.2 V6 4wd LS model and just shattered the back windshield (back glass) I have found numerous replacements for both rodeos and passports but I need to know which yr models/makes are correct fit for mine. I have the undermounted spare tire and yes I did have the defrost wires built-in to the glass...but I'm not even worrying about that part...just want to know which years/models would be a correct fit as the price varies by hundreds of dollars. THANK YOU!
wndrwmn069
Postby totten » Mon Nov 28, 2016 11:10 pm
Tad, site is not working,repair or delete it :?:
totten
Have thanks: 73 times
Previous
Users browsing this forum: geoffinbc, Google [Bot] and 2 guests
cron
