Late Model Isuzu FAQ
Postby Tad » Fri Oct 22, 2004 8:43 am
Here is an excellent reference. I've copied the index from it below the URL, and will update that index as I'm notified that it has changed on the page.
http://www.isuzufaq.com/
Index:
A. 30k Maintance?
1. I have a P0401 code, so how do I clean my EGR?
2. A.) I have a CODE P 440: Evap system, what is the problem?
2. My gas gauge is wrong how do I fix it?
3. My engine is knocking and ping�ing what can I do?
4. My truck seems to use a lot of oil, why?
5. I hear an air leak sound while the engine is running and my engine runs ruff, what could it be? Intake manifold gasket leaking: (P0300).
6. How to repack front wheel bearing, and when?
7. I have transmission problems ( ECU code: P1870).
8. I have lower gas mileage what can I do?
9. My Rodeo or Amigo thumps or clunks while stopping or taking off from a stop?
10. I want to change my timing belt what else should I change?
11. Where can I purchase OEM parts?
12. Where can I purchase non OEM parts?
13. Where can I buy OEM used parts (mirrors, wheels, lights, body parts . . . )?
14. My Check engine light came on, where can I get it read at?
15. How do I change the spark plugs and which plugs should I use?
16. How and when should I replace my fuel filter?
17. I have knocking sound under idle and and/or around 2500 RPM, what can I do?
18. I would like to replace my shocks, which one should I use?
19.
I would like to buy a lift, bumpers, locker or other off road equipment, where can I buy it from?
20. I want to replace my Amigo's hardtop with a soft top, is it possible?
21. Is there a serpentine belt diagram available?
22. My Truck takes a long time to start (cranks an excessive length of time).
23. How do I remove the stereo and speakers from My Rodeo/Amigo?
24. What does my warranty cover?
25. How do I keep my fog lights on with high or low beams?
26. The Alarm goes off randomly (when cold)?
27. Where can I check for Recall and/or TSB info?
28. I have my trouble code what does it mean?
29. Can I install a supercharger?
30. I would like to install a hitch, where can I buy it and now do I install it?
31. Do you have the Amigo song from 1998 (what goes down stairs sometimes in pairs . . . )?
32. What are some other Isuzu related Message forums?
33. How can I tint my Amigo's sunroof?
34. How can I Dynamat my Amigo/Rodeo?
35. How do I stop that popping noise when I open my door on my 98 and newer Rodeo or Amigo?
36. Where are there Isuzu Off Road events?
37. Where can I purchase a manual at?
38. Where can I purchase a hard top for my Amigo?
39. Squeaking sound coming from the hood, how do I fix it?
40. Are there any Isuzu news sites?
41. How do I reprogram my keyless entry fob?
42. How TOD (TORQUE-ON-DEMAND) works?
43. How do I check the fluid level on my Tranny?
44. What the heck is Direct Injection?
45. I'm sporadically losing power, what can it be?
46. How do I replace the bulbs in my tailights (Rodeo)?
47. How to change the Rear diffy Fluid:
48. My factory 6 disk CD player died (ERR3) what can I do?
49. I would like to add a high flow air filter, which one?
50. I want to replace my rubber bushings with poly ones, where can I buy some?
51. What does the Power and Winter buttons do?
52. Possible ways to help sensitive ABS brakes
53. How Performance Chips work?
54. How to Turn the ABS light off?
55. Rodeo or Amigo dash rattle?
56. Where in the antifreeze drain plug on the block?
57. Transmission leaking possibilities?
58. Transmission filter replacement and partial fluid swap?
59. faulty transmission range sensor
60. Intermittent wiper function has failed
Tad was thanked by:
bbastwdog118
Tad
Site Admin
Has thanked: 121 times
Have thanks: 95 times
Postby Axiom 02 » Sun Oct 24, 2004 1:20 am
great stuff - thank you!
86 P'up
92 Trooper
02 Axiom
Axiom 02
Postby dirthawker » Sat Dec 25, 2004 7:16 pm
thanks for the info. ive been trying to find a thunk for 6 mos and due to this i fixed it !! THANKS A MILLION......... BEST X-MASS PRESENT YET!!!
dirthawker
Postby Amigo-2k » Tue Feb 15, 2005 3:11 pm
one year and 32,000 hits later the FAQ's are still rolling!
new additions:
Electrical problems
Engine Stalling Problem (OBDII P Code P0101)
Sea Foam Opinions
Power Steering fluid replacement
Tips for removing the Alternator
How to replace the headlight bulb
Problems with the Drive by wire
4wd always on or doesn't work
Replacing the idler belt pulley
Torque spec intake manifold
Amigo-2k
Forum Admin
Postby Amigo-2k » Thu Mar 17, 2005 12:28 pm
69. Replacing the idler belt pulley
70. Torque spec intake manifold
71. Sunroof fixes
72. Windshield fluid tank leaks
73. Heater problems
74. How to Flush the radiator
75. Problems with turn directional
76. BRAKE light on
77. Key stuck in ignition
78. Clunking under Feet
79. Isuzu Engine Rebuild Kits
80. Firing Order
Amigo-2k
Forum Admin
Postby EmilioFabris » Thu Aug 04, 2005 9:26 pm
i cant get the link to work??? does any one else have this problem
EmilioFabris
Postby okiedude » Tue Oct 10, 2006 8:02 pm
EmilioFabris wrote:i cant get the link to work??? does any one else have this problem
Me too?
okiedude
Postby Grumpfrompahrump » Tue Oct 10, 2006 9:35 pm
This is the correct link:
http://isuzufaq.ibctech.ca/
It was a week or so ago, but this doesn't seem to be working either
Steve
2000 Amigo Ironman, 3.2L Auto 4WD
1982 Cadillac Fleetwood Hearse
1927 Ford Model T Roadster w/327 Chevy
Grumpfrompahrump
Have thanks: 35 times
Re: Late Model Isuzu FAQ
Postby Skeletor » Thu Jan 18, 2007 9:41 pm
[quote="Tad"]Here is an excellent reference. I've copied the index from it below the URL, and will update that index as I'm notified that it has changed on the page.
http://www.geocities.com/endre_rl/isuzufaq.htm
Great resource for the new vehicles..chock full of info...
is there one for older MK1 series ?
Skeletor
Postby DR1665 » Fri Jan 19, 2007 2:34 pm
FYI: I was reading up on EGR issues and found three out of four links were dead on the cleaning link. They go to some wierd sites that look like they came with someone's ISP. Just a thought.
GBXM|united. Gearheads like us.
1989 Mitsubishi Pajero, 2.6L SWB riding mower with a windshield
DR1665
Trail Rider
Postby lukosrage » Wed Sep 12, 2007 3:14 am
links are all dead
lukosrage
Postby RodeoRed » Wed Sep 12, 2007 10:47 am
(Former owner of a) '99 Rodeo 3.2 V6 A/T w/ 8" lift, 4.77's, Aussie Locked Rear
33" TrXus MT's, trailgear sliders, pacer flares
CB, superwinch 8000 lb & custom bumper,ProComp lights, custom rack, dents...
http://www.cardomain.com/ride/2231794
RodeoRed
Postby rodeoboy54 » Mon Oct 08, 2007 12:41 am
for the rebuild kits which one would work for a 3.1 91 2wd rodeo
1997 2 tone black rodeo 3.2 4wd *DD*
1991 FORD MUSTANG GT 5.0 5 speed!
rodeoboy54
Trail Scout
DI Spark Plugs are different!
Postby marcus550 » Sat Feb 02, 2008 2:54 pm
The FAQ lists the wrong spark plugs if you have a 2004+ Direct Injection 3.5l.
The OEM plugs are Denso Iridium SXU16HPR9. Everything about them is different from other Isuzu plugs. Confirmed by pulling the OEM plugs out to verify, and is also listed in the owner's manual. These should be good for 100k.
Mark
marcus550
Postby Philscbx » Fri Aug 01, 2008 12:58 am
The server at isuzufaq.ibctech.ca is taking too long to respond.
The requested site did not respond to a connection request and the browser has stopped waiting for a reply.
Just when you really wanted to see a possible answer.
Yeah! it finally works...
Solved the issue with friends clunk with auto tranny.
I'll bet the FAQ is correct with the fact the slip joint drive shaft is dry..
98 Amigo 4x4 v6 5 Speed
http://cardomain.com/id/Philscbx
Philscbx
Rodeo King
Postby Isuzu-Baby7 » Wed Mar 11, 2009 11:07 am
Great link. I might have more options now for my ever-breaking Rodeo!!!!! Yay! Thanks bunches! :D
Isuzu-Baby7
Love me, love my vehicles.
"Sender" 2000 Nissan Xterra 5spd 4X4... totally stock
"Myranda Murdock" '99 Rodeo LS 4X4... traded for the Xterra... bitter sweet...
"Muhnyrvuh the Tiny" 1985 Honda Rebel 250
"Ru Too" '90 Trooper... broken.... and still cool as hell...
... "Rufus" '87 Troop (R.I.P.)
Good Bye old friend... "Muhnyrvuh" '91 Amigo 5 spd. 2WD
Isuzu-Baby7
Postby RodeoRed » Sun Jun 21, 2009 8:02 pm
is this link now dead or is it just me
RodeoRed
Postby Alien5000 » Thu Jan 07, 2010 6:01 pm
It works for me.
Alien5000
Postby Chooie » Tue Jul 27, 2010 12:16 am
isuzufaq.com is asking for username/password.
Chooie
Postby Amigo-2k » Fri Aug 27, 2010 5:18 pm
The FAQ's has been updated. Cleaned up a bunch of dead links. Last update was 2007.
Amigo-2k
Forum Admin
Thanks
Postby trooper_march02 » Sat Dec 11, 2010 1:27 am
WOW... great info... Thanks for putting it together!!!!
2002 Trooper Limited built March 02. Has the screw in PCV value (the redesign engine).
My first Trooper was a 1992 LS. Bought it with 130,000 miles and loved it. Sold it with 200k miles and bought the 02 in 07.
Bought a new Rodeo LS late 1995. Blue and Silver with the running boards. Isuzu came out with the new interior mid year in 95, my wife and I both loved it. Sold the Rodeo in 2008. 12 plus years on the road and it was a great vehicle!
trooper_march02
Postby MetalMan » Mon Feb 14, 2011 3:26 pm
These links are all down.. is this hosted anywhere else?
MetalMan
Postby 94Rodayo4x4 » Fri Feb 25, 2011 2:16 pm
MetalMan wrote:These links are all down.. is this hosted anywhere else?
x2
Taylor H.
1994 Isuzu Rodeo S, MUA5, 4WD, V6, 31's- Sold :( Rest In Peace, Ticking Green Beast!
2000 TOYOTA 4Runner SR5, V6, Auto, 4WD
1.5" Lift, 265/75 Yokohama Geolandar A/T, PIAA 520's, 22" LED Light Bar, Flowmaster
Isuzu Parts for sale
94Rodayo4x4
Has thanked: 32 times
Have thanks: 47 times
Postby shaunatk » Wed Mar 02, 2011 2:32 am
x3
1999 Honda Accord 4dr - My daily driver with 245k+ miles
2011 Dodge Journey 3.6L - Wife's daily driver
1941 GMC 5.3l LSx powered street rod - Under construction (S-L-O-W-L-Y)
2001 Isuzu Trooper - Brand new factory short block, new torque converter, aftermarket stereo and component speakers with amplifier, tinted windows, plastidipped wheels and trim, etc. etc.
http://www.southwestohiohomeinspections.com
shaunatk
Postby shaneb » Fri Mar 04, 2011 1:32 am
Anyone?
1998 Trooper - some crap and two drivers side Oh S Bars
shaneb
Trail Rider
