1993 trooper lift?
1993 trooper lift?
Postby Izac94 » Wed May 17, 2017 10:24 pm
Hi I'll be getting a 1993 trooper 4x4 this coming week and cannot seem to find many options for getting a lift on it. Does anyone happen to know of any good sites to find a kit? Thanks in advance!
Izac94
Re: 1993 trooper lift?
Postby Tatohead » Thu May 18, 2017 12:13 pm
Hi
The most common, most basic, most CHEAP lift is a simple spacer/spring lift. The rear axle is lifted by either taller springs or adding spacers to the springs. The front is lifted by cranking up the T-Bars.
Here's a fun pictorial of doing this on my old Troop, the "Low Buck Special".
viewtopic.php?f=1&t=53712&p=453325&hilit=pictorial#p453325
1996 Accura SLX
AISIN Hubs / 2" Lift Springs / T-Bar Crank / G80 LSD
Tatohead
Has thanked: 13 times
Have thanks: 45 times
Postby Izac94 » Thu May 18, 2017 12:36 pm
Awesome! Thanks! I'll take a look and see what I can do! I'm only looking for an inch or too so I can put some bigger tires.
Izac94
Postby Tatohead » Thu May 18, 2017 3:16 pm
Izac94 wrote:Awesome! Thanks! I'll take a look and see what I can do! I'm only looking for an inch or too so I can put some bigger tires.
The Daystar spacers netted about 1.5", maybe a tiny bit less. There are taller springs out there that will give you more. Just that little 1.5 inches really helps clear bigger tires. I will be mounting 285/75/16 soon, and these supposed clear just fine without lift, but now I can be confident.
Good luck!
1996 Accura SLX
Tatohead
Postby Izac94 » Thu May 18, 2017 7:45 pm
Awesome sounds good. I will definitely try this out when I get the trooper going seems to be a really nice stance after the work. Where'd did you get the shocks and springs if you don't mind me asking
Izac94
Users browsing this forum: Google [Bot] and 6 guests
