1990 Trooper Makeover
Postby Panhandler » Wed May 17, 2017 9:05 pm
This is a continuation of the thread "Advice on Motor Swap 6cyl auto to 4cyl manual".
Due to various factors I decided to sell my '84 to a friend and focus on the '90 6cyl Auto. I've been steady stripping and cleaning. The HG is blown and the motor had a slight knock. I ran a bottle of miracle juice thru it to see what would happen. I changed the oil, refilling with a quart of Lucas and topped off with 10w-40. So far she runs okay in the driveway with no smoke or over heat issues. No water in the oil as of yet.
I'll continue to pull parts and clean and once insured and tagged I'll begin short trips around town. If the motor blows I'll rebuild the tranny and install a remanufactured motor. This seems the easiest and quickest way to a solid vehicle.
I'm sure I'll have many questions. I look forward to bringer her back to life.
Panhandler
Re: 1990 Trooper Makeover
Postby RickP » Wed May 17, 2017 9:57 pm
I hope your headgasket in a bottle works out for you. I hope you kept the headlights and grille from the 86. That's worth $200-250 by themselves.
RickP
Has thanked: 34 times
Have thanks: 42 times
Postby geoffinbc » Thu May 18, 2017 4:09 am
After reading your last thread on swapping your old 4 banger into the 90 I'm glad you decided not to. The V6 is much more fun to drive and reliable in the long term. Plus you can easily get parts for it.
If the motor goes then I highly suggest a 3.1L swap at the minimum. A Rodeo donor is a direct bolt in along with the ECM to control it. See my site for more details.
geoffinbc
Has thanked: 8 times
Have thanks: 323 times
Users browsing this forum: Bing [Bot] and 5 guests
