99 Honda Passport 3.2 V6 lower intake gaskets question
Postby Ray7751 » Sun May 14, 2017 2:36 am
Ordered a 3 piece intake manifold gasket set from Fel-Pro for a 99 Honda Passport 3.2 V6 manual 5 speed. My question is, do you need black rtv sealant on all 4 corners of the lower gaskets? RTV on the top of the lower intake manifold gaskets in all 4 corners also? I know, NO rtv gasket sealer is needed for the upper intake gasket. I'm not so great with words. Any help if you can understand me would be great!
Ray7751
Has thanked: 2 times
Re: 99 Honda Passport 3.2 V6 lower intake gaskets question
Postby JLEMOND » Sun May 14, 2017 5:06 pm
NO RTV NEED ON THE LOWER GASKETS ,NONE NEEDED ON THE PLENUM CHAMBER TOP TO LOWER MANIFOLD . , DONT FORGET AND OVERTORQUE THAT INTAKE MANIFOLD BOLTS 13 FT LB,S MAX OR YOU MAY C RACK THE LOWERS AGAIN.
JLEMOND
Have thanks: 247 times
Postby Ray7751 » Tue May 16, 2017 2:16 am
Thanks JLEMOND. I thought you could do 17-18 FT LBS on the new Fel-Pro gasket set. I did purchase a new gasket set from O'riellys. Part#MS90610
Ray7751
Postby Ray7751 » Tue May 16, 2017 2:20 am
I remember the older ones for 13 ft pounds that needed that 13. Stock gaskets with that plastic type of material in the middle, easily cracks.
Ray7751
Users browsing this forum: Google Adsense [Bot] and 4 guests
