'92 Amigo "ice water swishing" glovebox sound on cold start
Postby 5009TWI » Wed May 10, 2017 9:37 pm
Started about a month after i got the truck last May. Was barely noticeable when it started. As mentioned in this video...
https://1drv.ms/v/s!AnfueX64pupJ9QFexqUljwS2qN8F
...it only happens on cold start, and is gone by the time the engine is fully warmed up.
Notes:
1) i haven't checked the a/c condensation drain as i never use the a/c
2) steering back and forth doesn't seem to have any effect on the sound but accelerating does (the sound becomes more intense and prolonged as RPM climbs but momentarily vanishes each time i shift gears)
3) doesn't seem to be affected by ambient conditions (temperature, himidity, etc)
It's got me stumped but hopefully somebody here has encountered it.
1992 Amigo S 2WD 4ZE1 5spd "Pequeña Blanca" Went on the hunt for a sensible, practical commuter car and instead I ended up buying this.
1997 Trooper S-Pep 5spd "Midori" Project car; engine rebuild currently on pause due to new job across the country.
1990 GMC Suburban R1500 SLE 350TBI "Regina" Daily driver from 2005 all the way until I bought the Trooper in 2015. Has resumed a well-deserved long nap until I can throw in an LQ4 & T56.
5009TWI
Re: '92 Amigo "ice water swishing" glovebox sound on cold st
Postby geoffinbc » Thu May 11, 2017 10:22 am
Turn the heater to full hot. Does the sound go away? It may be water getting forced through the valve when the rpms rise because the water pump spins faster and builds more pressure.
geoffinbc
Has thanked: 8 times
Have thanks: 324 times
Postby fourzeedee1 » Thu May 11, 2017 1:47 pm
I had a similar sound occur when the antifreeze gets low / air in the system. I have a heater core dribble leak that I have to top off every couple of months.
1986 Trooper II
2.3L
stock, stock, stock
My resto' thread - viewtopic.php?t=40050
Road Trippin' - viewtopic.php?f=1&t=43734&p=348062&hilit=chelan#p348062
fourzeedee1
Trail Scout
Have thanks: 9 times
Postby 5009TWI » Thu May 11, 2017 1:53 pm
Great suggestion. I kept thinking it was related to the heater core but forgot to consider constant coolant loss (and resulting bubbles) from the warped head.
Will test next time i take it out. Trying to limit driving as the engine gets worse and a rebuild inches closer. This post was meant collect suggestions i could try all at once.
Thanks
5009TWI
Users browsing this forum: No registered users and 5 guests
