1st gen troopers expedition rig fully loaded MPG
Postby CalenK » Tue May 09, 2017 10:04 pm
Hi everyone, did some searching but didn't really find exactly the info I was looking for. I want to know what kind of Gas milage people are getting in there fully loaded expedition ready 1st Gen troopers. I have a 89 2.6 4 door, 2" suspension lift, 31" tires, off road bumpers, roof rack, loaded with camp gear, one 20L jerry can and 20L of water, plus 4 passengers. with all that considered on a trip that consists of half highway and half off road, I get 260-280 out of a full tank. Is that normal? should I get more? what are other people getting with similar rigs?
thanks for any input!
89 Trooper 2.6: 2.25" OME SL, 1" BL, 1 piece drive shaft, custom bumpers, Inti roof rack
CalenK
Has thanked: 13 times
Re: 1st gen troopers expedition rig fully loaded MPG
Postby RickP » Tue May 09, 2017 11:06 pm
How many exact gallons you are putting in to those miles? Is you're speedometer accurate? With 30.50" inch tires, my speedo reads slow 9%, so I multiply my miles driven by 1.09 first and then divide by the gallons used . I would suspect 14-15 MPG would be what you could expect. I was consistently getting 15-16 unloaded and no roof rack and then about a month and a half ago, it has magically been getting 20.25 mpg the last several tanks.
RickP
Has thanked: 38 times
Have thanks: 44 times
Postby oldestisuzuist » Tue May 09, 2017 11:14 pm
Check the door pillar for stock tire size, if 235/75R-15s you're actually travelling about 7% farther than the odometer reading with the 31s. A loaded roof rack adds a lot of wind drag, couple that with the weight of the passengers & gear then your near 14mpg average seems fine to me.
'78 LUV, 1.9, headers, 4-spd, SAS Dana 30 front, Dana 20, SOA rear w/Aussie Locker, 31's, serious body cancer, bought new 12/4/78.
'87 Trooper, 2.3, headers, 5-spd, 31's, ball joint flip, Aussie Locker rear, Superwinch hubs, brush guard w/5.5K winch, needs motor, work in progress.
oldestisuzuist
Have thanks: 251 times
Postby CalenK » Tue May 09, 2017 11:31 pm
The exact gallons going into those miles is 22 gallons( a full 89 trooper tank). I understand that all those extras add drag and weight, thats why I want to know what MPG other people are getting with similar setups. Most MPG calculations I can find are from people without those extras, driving stock troopers, that are not caring full loads of gear, extra gas, water, passengers... I also understand that tire size difference from stock effects the tripometer/spedometer/odometer. so really all I want to know is how many miles people are traveling in similar rigs on a full tank of gas.
CalenK
Postby paulevans76 » Wed May 10, 2017 9:29 am
I wouldn't expect better than 15mpg on the highway when loaded down like that... throw in the off road and I think you are about normal.
Has thanked: 92 times
Have thanks: 87 times
Postby squatch » Wed May 10, 2017 10:19 am
A 2.6 Trooper on stock tires gets 17-20 mpg. One loaded down with 31's and stock gears gets 15-17 mpg.
Red Beans with 4:77's and 32's. Hot cam and exhaust gets 15+ loaded for bear and towing my boat.
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
For this post the author squatch was thanked by:
CalenK
squatch
Has thanked: 66 times
Have thanks: 328 times
Users browsing this forum: Yahoo [Bot] and 6 guests
