Keep blow 10AMP AC Fuse
Postby Mhartwig » Tue May 09, 2017 1:51 pm
I have been able to get cold air from the AC, so I know the compressor works. However, I am constantly blowing the 10AMP AC Fuse. Most of the time it blows immediately when turning on the AC. Any ideas on what/where to check?
Mhartwig
Re: Keep blow 10AMP AC Fuse
Postby RickP » Tue May 09, 2017 3:48 pm
Typically that is caused by a bad compressor clutch.
RickP
Has thanked: 38 times
Have thanks: 44 times
Postby Darby » Tue May 09, 2017 4:06 pm
Disconnect the wire from the compressor and see if it still does it.
Original owner of a 1993 Isuzu pick up, 2.3 engine, 5 speed with power steering and air conditioning. All original except the radio (still have factory radio).
It's cheaper to fix what you have than to buy someone else's problems.
Darby
Have thanks: 19 times
Postby 6079smithw » Wed May 10, 2017 1:11 am
I had that happen on my '94 Trooper. Turned out the wire to the compressor clutch was rubbing against the compressor frame and the insulation had chafed through. Direct short to ground. Check the lead from the clutch back to the loom and make sure the insulation is intact. Hopefully that's your problem and not the clutch which is a PITA to replace... :cry: Good luck!
2001 Rodeo LS 4WD AT 164k Bone Stock 01-14-2017
1994 Trooper SE DOHC AT 145k
1987 Wrangler 2.5L 5-spd 87k All Original
2001 Saturn SL1 353k Retired May 2017
1993 Saturn SL1 5-spd 227k Work car RIP
6079smithw
Postby Georgia159.com » Wed May 10, 2017 8:56 am
Not sure if you are talking the compressor fuse or the ac blower fuse (which will also shut down the compressor). I've had both issues previously.
Fuse to compressor - I had had a front end collision with a deer and the harness had gotten pinched. Had to track down with wiring diagrams and multi meter, and replace some shorted wires.
AC Blower fuse - The blower has been replaced and the aftermarket connector literally melted and was shorting out. (I run ac all the time, it's the South!) The pics are no longer on my server but the thread is here: http://www.planetisuzoo.com/viewtopic.php?f=1&t=71241
199? Rodeo (ISO of my next project truck- being picky)
1997 Rodeo 2WD 3.2 V6 Auto (4-1-13 - Purchased for $580. Best deal ever. My DD.)
1994 Rodeo LS 2WD 3.2 V6 Auto (2015 - Bought for Parts, but still running! The Backup.)
1997 Honda Passport 2WD 3.2 V6 Auto (2015 - Parts donor - PM if you need something)
Georgia159.com
Has thanked: 17 times
Postby Mhartwig » Wed May 10, 2017 2:30 pm
Thanks, Ill follow the wire and maybe get a new relay as well. It is the compressor fuse.
Mhartwig
Users browsing this forum: Baidu [Spider], Yahoo [Bot] and 6 guests
