2001 Isuzu Rodeo LS 2WD Popping Noise
Postby Trebtown » Tue May 09, 2017 10:53 am
When I turn and break at low speeds there is a popping noise and I can't seem to figure out what it is..Any help would be nice!
Trebtown
Re: 2001 Isuzu Rodeo LS 2WD Popping Noise
Postby PA_Robert » Sun May 14, 2017 10:56 pm
How many miles on it and do you know the maintenance history?
Could be a number of things but ball joints could be the most likely problem.
1999 Rodeo. 2WD. Auto. 3.2. Green in color. Nice Rig.
PA_Robert
Has thanked: 7 times
Postby Trebtown » Sun May 14, 2017 10:59 pm
175k but it looks like the boots are in bad shape
Trebtown
Postby PA_Robert » Sun May 14, 2017 11:06 pm
Check you tube videos on how to check for front end issues.
Ball joints are easy to check. Jack car up until wheel is off ground rock tire at the 12:00 and 6:00 or put 3' pry bar under tire and have someone watch movement.
Best to watch videos. a video is worth 10,000 words.
Does it only happen when braking and turning? I found my problem with ball joints when turning, accelerating and some bumps in the road.
PA_Robert
Users browsing this forum: Google Adsense [Bot] and 3 guests
