'89 2.6 Exhaust Manifold
Postby SurferJoe » Sat Apr 15, 2017 1:09 am
This is the 4th time I've created a hole in the exhaust manifold, right on the inside of the casting, engine-side before the oxygen sensor. Anyone else have this problem?
I'm getting tired of buying new and used parts - I had one time where I welded a plate over the hole and it worked for a couple of years before it fell off.
Cast iron is tough to weld with all the silicon that rises to create a 'no-weld' zone.
Grey Works can ship me a new one if I go for it again.
Joe Vreeland - In The Bitterroot Valley, Montana
SurferJoe
Has thanked: 24 times
Have thanks: 25 times
Re: '89 2.6 Exhaust Manifold
Postby squatch » Sat Apr 15, 2017 11:22 am
Stock manifold is prone to cracking. Replace it with a header and forget about it.
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 66 times
Have thanks: 326 times
Postby SurferJoe » Mon Apr 17, 2017 12:53 am
I'm leaning that way too.
SurferJoe
Postby hessmess » Thu Apr 20, 2017 1:59 pm
I took the heat shield off of my manifold when I replaced it last time. No problems since then.
88 Trooper (recycled)
viewtopic.php?f=15&t=81567
89 Pup LS Space Cab, 4X4, AMC head, Delta 260 cam, 2.25 cat back exhaust system, LSD
viewtopic.php?t=55081
For this post the author hessmess was thanked by:
rbral
hessmess
Have thanks: 141 times
Postby SurferJoe » Fri Apr 21, 2017 12:31 am
Hmmm. I've always kept it on..
Mebeeeeeeeee!
SurferJoe
